[snappyHexMesh] snappy mesh for fluid with porous zone |
January 24, 2017, 01:52 |
Vaze
Rep Power: 16 |
Hi all
I am new to foam. I want to model flow through porous zone. I have porous zone geometry in stl format. I want to use snappy. I have doubt about locationInMesh because this refers to the zone of mesh. While in my case I want to keep fluid (blockMesh) mesh as well as mesh created inside stl file through snappy. Would anyone tell me how can i do it? Regards Mvee |
February 23, 2017, 01:13 |
Rep Power: 24 |
Basically for multi-region snappy the location doesn't matter. Put it inside one of your domains. You will tell each STL to be in a different cellZone and snappy will extract them all, including ones you may not want. After you just delete the ones you don't want.
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 21:41 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
