[mesh manipulation] Rotating 2D mesh
Old   January 31, 2017, 05:26
Default Rotating 2D mesh
Emre
ordinary is on a distinguished road
I'm trying to rotate my 2D mesh by centroid of the object. (i.e. I'm yawing it 50 degrees)
surfaceTransformPoints -rollPitchYaw (0 0 50) old.stl new.stl
Unfortunately it rotates the object by global coordinate system. Here it is:
I tried to change relevant source code below, but it seems confusing:
    else if (args.optionFound("rollPitchYaw"))
        vector v(args.optionLookup("rollPitchYaw")());
        Info<< "Rotating points by" << nl
            << "    roll  " << v.x() << nl
            << "    pitch " << v.y() << nl
            << "    yaw   " << v.z() << endl;
        // Convert to radians
        v *= pi/180.0;
        quaternion R(v.x(), v.y(), v.z());
        Info<< "Rotating points by quaternion " << R << endl;
        points = transform(R, points);
If you have any idea, please do not hesitate to reply.
Thank you.
ordinary is offline   Reply With Quote
rollpitchyaw, rotating, surfacetransformpoints
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
Rotating Mesh with pympleDyMFoam WernerW OpenFOAM Running, Solving & CFD 1 August 20, 2015 14:34
[ICEM] Rotating Mesh and export Mesh ahmadreza ANSYS Meshing & Geometry 10 July 12, 2015 04:17
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
