[Commercial meshers] STAR CCM+ mesh to Foam in OpenFoam 2.4
Old   December 17, 2015, 02:57
Default STAR CCM+ mesh to Foam in OpenFoam 2.4
Gajendra Gulgulia
ggulgulia is on a distinguished road
Hello all,
I am a new user of OpenFoam. I am practicing with OpenFOAM V 2.4 . When am trying to convert a STAR CCM Mesh to FOAM Mesh using the following command:
# $ ccm26ToFoam mesh_name.ccm
i am getting the following error saying command not found.
is this command not supported on Foam 2.4 ?
Replies/suggestions appreciated
ggulgulia is offline   Reply With Quote
Old   December 17, 2015, 03:39
W.T
dybuk is on a distinguished road
As far I know ccm26ToFoam depends on ibccmio which is properitary and it's not build by default. You should compile ibccmio and ccm26ToFoam.
This information can be found in readme file for ThirdPart packages
https://github.com/OpenFOAM/ThirdPar...ter/README.org
dybuk is offline   Reply With Quote
Old   December 18, 2015, 00:59
Gajendra Gulgulia
hello Dybuk,
Thanks a lot for the suggestion, was very helpful
Old   December 19, 2015, 13:18
Retired Super Moderator
Bruno Santos
Quick answer: http://openfoamwiki.net/index.php/Ccm26ToFoam
Old   February 2, 2017, 07:46
Ricky
kera is on a distinguished road
hello all,
I have one question, is there any way to mapFields from star-ccm to OpenFOAM, something like fluentDataToFoam? (i.e., converting the star-ccm data to OpenFOAM readable data first)
I have some simulation results in star-ccm, which I want to use as my initial condition in OpenFOAM. It would really save me a lot of time, if I avoid re-simulating those cases again in OpenFOAM.
Any help is really appreciated.
Regards,
Ricky
kera is offline   Reply With Quote
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 11:32
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 22:07
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
