[snappyHexMesh] Create patches after snappyHexMesh
Old   April 21, 2015, 06:51
Default Create patches after snappyHexMesh
Sebastian Trunk
sisetrun is on a distinguished road
Hello Foamers,
I successfully created my mesh using snappyHexMesh (tube with a sphere inside; or better: cylinder with flow resistance).
Now, I want to define an inlet / out / wall patch for my BC.
What is the best way to do this after snappyHexMesh?
Thanks a lot
sisetrun is offline   Reply With Quote
Old   February 9, 2017, 09:27
Sebastian Trunk
I found my own thread and meanwhile a have the solution:
once you have created your mesh, you can use the setSet utility to make a cellSet c1 from given stl by surfaceToCell.
*Than, make a faceSet f1 from the cellSet c1.
*Make a second faceset f2 with patchToFace from the patch (existing patch after mesh generation)
*Subset f2 with f1
use the resulting f2 in the createPatch utility
-> edit the BC for the new patch
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Patches disappear after snappyHexMesh Chris123 OpenFOAM Running, Solving & CFD 2 March 5, 2019 09:09
[snappyHexMesh] Create three patches along a tube RobertHB OpenFOAM Meshing & Mesh Conversion 2 June 1, 2018 03:53
[GAMBIT] How to plot S pipe mariam.sara ANSYS Meshing & Geometry 36 November 7, 2013 15:22
[snappyHexMesh] Is it possible to create a "complex" mesh using snappyHexMesh? rendagar OpenFOAM Meshing & Mesh Conversion 3 October 17, 2013 02:56
