[snappyHexMesh] Create patches after snappyHexMesh |
April 21, 2015, 06:51 |
Sebastian Trunk
Rep Power: 11 |
Hello Foamers,
I successfully created my mesh using snappyHexMesh (tube with a sphere inside; or better: cylinder with flow resistance). Now, I want to define an inlet / out / wall patch for my BC. What is the best way to do this after snappyHexMesh? Thanks a lot |
February 9, 2017, 09:27 |
Sebastian Trunk
Rep Power: 11 |
I found my own thread and meanwhile a have the solution:
once you have created your mesh, you can use the setSet utility to make a cellSet c1 from given stl by surfaceToCell. *Than, make a faceSet f1 from the cellSet c1. *Make a second faceset f2 with patchToFace from the patch (existing patch after mesh generation) *Subset f2 with f1 use the resulting f2 in the createPatch utility -> edit the BC for the new patch |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Patches disappear after snappyHexMesh | Chris123 | OpenFOAM Running, Solving & CFD | 2 | March 5, 2019 09:09 |
[snappyHexMesh] Create three patches along a tube | RobertHB | OpenFOAM Meshing & Mesh Conversion | 2 | June 1, 2018 03:53 |
[GAMBIT] How to plot S pipe | mariam.sara | ANSYS Meshing & Geometry | 36 | November 7, 2013 15:22 |
[snappyHexMesh] Is it possible to create a "complex" mesh using snappyHexMesh? | rendagar | OpenFOAM Meshing & Mesh Conversion | 3 | October 17, 2013 02:56 |
