[blockMesh] Error in Axis-Symetrical problem using ExtrudeMesh |
February 17, 2017, 05:45 |
Bharat Kumar
Hi all,
I am a beginner in OpenFOAM and I am trying to create a cylinder using wedge extrusion in ExtrudeMesh. I created a slab using blockMesh and I want to extrude the face of the slab around an axis. But I couldnot do it succesfully. I am getting the same error no matter what changes I do. Pls help. My error is "--> FOAM FATAL ERROR: wedge inlet plane aligns with a coordinate plane. The wedge plane should make a small angle (~2.5deg) with the coordinate plane and the the pair of wedge planes should be symmetric about the coordinate plane. Normal of wedge plane is (1.22465e-16 1 -8.34056e-34) , implied coordinate plane direction is (0 1 -0) From function virtual void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamBu ffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 109" My blockMeshDict and extrudeMeshDict are as follows for your reference. Thanks in advance. blockMeshDict: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // General macros to create 2D/extruded-2D meshes // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (20 0 0) (65 0 0) (64.9901001852 1.1344064184 0) (19.9969539031 0.3490481287 0) (20 0 40) (65 0 40) (64.9901001852 1.1344064184 40) (19.9969539031 0.3490481287 40) ); edges ( line 0 1 line 3 2 line 7 6 line 4 5 arc 0 3 (19.9992384613 0.17453071 0) arc 1 2 (64.9975249992 0.5672248074 0) arc 5 6 (64.9975249992 0.5672248074 40) arc 4 7 (19.9992384613 0.17453071 40) line 0 4 line 1 5 line 2 6 line 3 7 ); blocks ( hex (0 1 2 3 4 5 6 7) (18 1 18) simpleGrading ( ( //X dir (0.2 0.3 4) (0.6 0.4 1) (0.2 0.3 0.25) ) 1 //Ydir ( //Z dir (0.2 0.3 4) (0.6 0.4 1) (0.2 0.3 0.25) ) ) ); boundary ( inlet { type cyclic; neighbourPatch outlet; faces ((0 1 5 4)); } outlet { type cyclic; neighbourPatch inlet; faces ((3 7 6 2)); } bottom { type wall; faces ((0 3 2 1)); } top { type patch; //(or wall) faces ((4 5 6 7)); } ext_wall { type wall; faces ((0 4 7 3)); } inner_wall { type wall; faces ((6 5 1 2)); } ); ExtrudeMeshDict: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object extrudeMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // What to extrude: // patch : from patch of another case ('sourceCase') // mesh : as above but with original case included // surface : from externally read surface //constructFrom mesh; constructFrom patch; //constructFrom surface; // If construct from patch/mesh: sourceCase ; sourcePatches (inlet); // If construct from patch: patch to use for back (can be same as sourcePatch) exposedPatchName outlet; // If construct from surface: //surface "surface_name.stl"; // Flip surface normals before usage. Valid only for extrude from surface or // patch. flipNormals false; //- Linear extrusion in point-normal direction //extrudeModel linearNormal; //- Linear extrusion in specified direction //extrudeModel linearDirection; //- Wedge extrusion. If nLayers is 1 assumes symmetry around plane. extrudeModel wedge; //- Extrudes into sphere around (0 0 0) //extrudeModel linearRadial; //- Extrudes into sphere around (0 0 0) with specified radii //extrudeModel radial; //- Extrudes into sphere with grading according to pressure (atmospherics) //extrudeModel sigmaRadial; //nLayers 10; nLayers 180; //expansionRatio 1.0; //0.9; sectorCoeffs { axisPt (0 0 0); axis (0 0 1); angle 360; // For nLayers=1 assume symmetry so angle/2 on each side } /*linearNormalCoeffs { thickness 0.1; }*/ /* linearDirectionCoeffs { direction (0 1 0); thickness 0.05; } */ /* linearRadialCoeffs { R 0.1; // Optional inner radius Rsurface 0.01; } */ /* radialCoeffs { // Radii specified through interpolation table R table ((0 0.01)(3 0.03)(10 0.1)); } */ /* sigmaRadialCoeffs { RTbyg 1; pRef 1; pStrat 1; } */ // Do front and back need to be merged? Usually only makes sense for 360 // degree wedges. mergeFaces true; //true; // Merge small edges. Fraction of bounding box. //mergeTol 0; |
Unsteady Boundary Profile with data file | Arianna | FLUENT | 34 | July 29, 2019 16:35 |
BuoyantBoussinesqSimpleFoam_Facing problem | Mondal131211 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2019 19:41 |
[blockMesh] Wierd behaviour of blockMesh creating axis in wedge | rcastilla | OpenFOAM Meshing & Mesh Conversion | 1 | December 4, 2018 06:24 |
Problem with Axis of rotation in Periodic BC | mohammad | STAR-CCM+ | 2 | September 5, 2014 05:33 |
Periodic flow boundary condition problem | sudha | FLUENT | 3 | April 28, 2004 08:40 |
