[blockMesh] blockMesh Projection doubts
Old   August 6, 2018, 16:10
Default blockMesh Projection doubts
Gabriel Gomes de Castro
GabsGC is on a distinguished road
Hello foamers,
I'm brand new to OpenFoam and CFD in general, currently trying to mesh the internal cavity of a two stroke engine, with both inlet and outlet cavities.
I've read that using searchableCylinder and vertice projection is a good way but from the openFoam tutorials I could not understand the syntax of the projection and got really lost with the 'pipe' native example.
Looking for help with the syntax and suggestions on other meshing options.
GabsGC is offline   Reply With Quote
cylinder, engine simulation, projection
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
[snappyHexMesh] Problem and doubts with blockMesh, snappyHexMesh and multiple geometry luca1992 OpenFOAM Meshing & Mesh Conversion 0 August 23, 2017 11:40
[snappyHexMesh] Doubts about how larger mesh done with blockMesh affects boundaries in snappyHexMesh rosario OpenFOAM Meshing & Mesh Conversion 1 April 28, 2016 05:34
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
