March 4, 2017, 05:38 |
Trapezoidal blockMesh
badoumba
Rep Power: 12 |
I remember having seen an aircraft aerodynamics project where the team set an initial trapezoidal blockMesh shape so the turbulences which spread at the back follow more or less the block cells pattern and not crossing the cells like in the case of straight block.
Do you think this approach really makes a difference for convergence? Is it is so, can we set a slip condition on the sides which are not parallel any more to the inlet flow direction? Thanks! |
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 7 | August 25, 2020 19:15 |
[blockMesh] blockMesh not producing straight lines when using edgeGrading | ivan_CFD | OpenFOAM Meshing & Mesh Conversion | 0 | February 1, 2019 09:21 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
[blockMesh] set of xyz data in blockMesh | psk | OpenFOAM Meshing & Mesh Conversion | 12 | August 27, 2013 08:37 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 11:59 |
