April 30, 2017, 16:18 |
Diagonal extrusion in gmsh
Declan
Rep Power: 9 |
Hi All
I am trying to extrude a surface (height h1) along the z-direction with: - the top being extruded horizontally a distance d1, then d2, then d1 again - the bottom extruded diagonally at an angle θ (see 2D diagram) Does anyone have any ideas on how to achieve this? Any help appreciated Declan PS I have attempted a solution involving the Translate function but it is messy and doesn't produce a space with contiguous cells. I am looking for a cleaner approach! |
May 1, 2017, 04:02 |
Could you elaborate, why can't you extrude surface (ruled plane in gmsh terms), that you have drawn on the scheme in Y direction (i.e. normal to the screen)? |
May 1, 2017, 04:24 |
Declan
Rep Power: 9 |
Hi Alexei,
In the y direction normal to the screen there are complicated features in the geometry so I created that plane (xy) first and planned on extruding in the z-direction |
May 1, 2017, 06:08 |
Declan
Rep Power: 9 |
For example is it possible to introduce a conditional function in the extrude command? Like Extrude{x,f(y),z}{...}
where f(y) would be given by something like: If y= h1 then f(y)=h1-(extrudeDepth*Tanθ); else y=0; |
May 1, 2017, 07:01 |
No, you can not introduce conditional functions into extrude.
And I still do not understand what you are trying to achieve. Plane, which you extrude, has complex geometry and you would like to extrude and scale at the same time? Here is an example that works in Gmsh 3.0.1: Code:
Extrude {0, 0, 10} { Surface{1}; } Dilate {{0.5, 1, 10}, {0.5, 0.5, 0.5}} { Surface{26}; } Could you describe your whole problem? Maybe your are trying to solve it in non-Gmsh way. |
rhoCentralFoam diverges | Dorian1504 | OpenFOAM Running, Solving & CFD | 4 | December 10, 2017 14:22 |
GMSH Error: Degenerated Hexahedron in extrusion of volume | hemaditya | Mesh Generation & Pre-Processing | 0 | June 23, 2016 04:51 |
why divergence occures in these cases | immortality | OpenFOAM Running, Solving & CFD | 2 | January 25, 2013 10:21 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
