April 27, 2017, 16:29 |
Failed 2 mesh checks
sandy
Rep Power: 10 |
I am trying to create axisymmetric 2-d case for flow inside VERTICAL CYLINDER. i am creating a wedge of 2.5 degree with two zones inside. a (cylinder) inner zone for gas and thin liquid film near outer cylinder wall but i am unable to get rid of error regarding highly aspect ratio mesh and non aligned cells due to small angle of 2.5 degree. any solution??
Checking geometry... Overall domain bounding box (0 0 -0.000261779) (0.012 0.2 0.000261779) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 1) Wedge front with angle 1.25 degrees Wedge back with angle 1.25 degrees ***Number of edges not aligned with or perpendicular to non-empty directions: 239520 <<Writing 120242 points on non-aligned edges to set nonAlignedEdges Boundary openness (-6.00434e-18 4.22958e-17 -7.1526e-16) OK. ***High aspect ratio cells found, Max aspect ratio: 599952, number of cells 60000 <<Writing 60000 cells with high aspect ratio to set highAspectRatioCells Minimum face area = 1.21203e-12. Maximum face area = 3.33333e-05. Face area magnitudes OK. Min volume = 2.42407e-13. Max volume = 2.88464e-11. Total volume = 6.28319e-07. Cell volumes OK. Mesh non-orthogonality Max: 1.70755e-06 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.333333 OK. Coupled point location match (average 0) OK. Failed 2 mesh checks. |
failed mesh checks, not aligned |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[blockMesh] Failed 1 Mesh checks !! ? | T.D. | OpenFOAM Meshing & Mesh Conversion | 3 | February 24, 2011 17:39 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
