[blockMesh] Simple cylindrical geometry: example using blockMesh
Like Tree6Likes
  • 6 Post By guin
Old   June 19, 2017, 05:59
Default Simple cylindrical geometry: example using blockMesh
Rodrigo
guin is on a distinguished road
Here you have an example of blockMeshDict file that uses macro substitution to generate a simple cylindrical geometry based on a few user input values.
Well, actually it only generates 1/4th of the cylinder, which allows to keep the file reasonably small. You can make use of mirrorMesh to generate the complete cylinder, e.g.:
blockMesh
cp system/mirrorMeshDict_xAxis system/mirrorMeshDict
mirrorMesh -overwrite
cp system/mirrorMeshDict_yAxis system/mirrorMeshDict
Hope someone finds it useful.
mstf_aa, tzaht, Fabiio87 and 3 others like this.
guin is offline   Reply With Quote
[ANSYS Meshing] 2D equilaterals triangles in simple geometry Ulixes ANSYS Meshing & Geometry 0 June 16, 2017 19:01
[snappyHexMesh] unsymmetric boundary layer extrusion on simple symmetric geometry Attesz OpenFOAM Meshing & Mesh Conversion 1 April 25, 2017 07:13
FloTHERM: How to convert the cylindrical geometry to Cylinder SmartPart? olsmir FloEFD, FloWorks & FloTHERM 4 November 25, 2016 09:08
simple geometry and potentialFoam? Tobi OpenFOAM 0 June 21, 2012 16:39
Floating point error in BlockMesh for really simple mesh CoenW OpenFOAM Bugs 3 July 22, 2009 06:33
