[Other] Mesh Check Fail - Unknown Cause
Old   June 28, 2017, 00:59
Default Mesh Check Fail - Unknown Cause
Alwin
sdfij6354 is on a distinguished road
I have a domain of 300x1x200 cells containing a geometry (a greenhouse) in the center.
The meshing itself works fine, but when performing a mesh check I get the error "Failed 1 Mesh Check".
I think this might be important because later on (when solving the case - airflow from inlot to outlet over the greenhouse) I get "time step continuety errors" when solving for p.
Does anyone has an idea where the mesh error might come frome? I attached the mesh check log as an .pdf.
I'm quite new to OpenFoam. I modeled other cases before and never encountered this problem.
sdfij6354 is offline   Reply With Quote
Old   June 28, 2017, 08:21
sati is on a distinguished road
There must be a problem in your bc definition. Check that all your boundaries on the /y direction are set to empty, and that those on the /x and /z direction are defined.
sati is offline   Reply With Quote
Old   June 28, 2017, 10:36
Alwin
thank you for your answer.
I just checked: If I perform a mesh check directly after meshing, it says "meshing check ok". (all parts of the domain/geometry are defined as "walls").
The mesh check error starts to appear as soon as I define the boundary conditions of my y direction (front and back part of the domain) as "empty".
At this time, all other parts of the domain/geometry are still defined as "walls".
What could be the reason for this? My geometry of the greenhouse?
I'm wondering why because this is how I usually defined all my other 2D cases - a depth in the y-direction of 1 cell and setting the front/back boundary as empty.
P.S.: My geometry is 3D and actually larger than the domain in y-direction (like "sticking out" of the domain). Since I only want do solve the case in 2D I set y = 1 cell in the domain. Is this correct?
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[Commercial meshers] Problems with ANSYS mesh conversion tdog OpenFOAM Meshing & Mesh Conversion 1 March 31, 2016 17:36
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
[Commercial meshers] case File with a polyhedral mesh to OpenFoam Christoph_84 OpenFOAM Meshing & Mesh Conversion 2 April 26, 2013 10:07
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
