[blockMesh] How to get rid of defaultFaces
Prev Previous Post   Next Post Next
Old   June 3, 2020, 01:25
Default How to get rid of defaultFaces
felipe ortega
flowwwww is on a distinguished road
Hello everyone,
I am working in the creation of a domain with blockMesh to simulate a problem. This domain is quite simple, but i have not could reach a good result due to the defaultFaces.
The domain that i am trying to obtain is the following.
This domain must fit in my geometry.
However, when i create the blockMeshDict file and obtain the result that i am looking for, between the boundarys , appears four defaultFaces that are located into the geometry, and when i try to mesh the geometry with snappyHexMEsh, the geometry get cut by the defaultFaces and dont let it be meshed.
Can i get rid of the defayltFaces or disable them.
convertToMeters 1;
vertices
    (0 0.39 0)
    (0.16 0.39 0)
    (0.16 3.31 0)
    (0 3.31 0)
    (0 0.39 0.54)
    (0.16 0.39 0.54)
    (0.16 3.31 0.54)
    (0 3.31 0.54)//7
    (1.11 0.39 0)
    (1.11 3.31 0)
    (0.16 0.39 0.3)
    (1.11 0.39 0.3)
    (1.11 3.31 0.3)
    (0.16 3.31 0.3)//13
    (1.11 3.7 0)
    (0.16 3.7 0)
    (1.11 3.7 0.3)
    (0.16 3.7 0.3)//17
    (1.11 0.39 0.54)
    (1.11 3.31 0.54)//19
    (19.34 0.39 0)
    (19.34 3.31 0)
    (19.34 0.39 0.54)
    (19.34 3.31 0.54)//23
    (20.29 0.39 0)
    (20.29 3.31 0)
    (19.34 0.39 0.3)
    (20.29 0.39 0.3)
    (20.29 3.31 0.3)
    (19.34 3.31 0.3)//29
    (20.29 3.7 0)
    (19.34 3.7 0)
    (20.29 3.7 0.3)
    (19.34 3.7 0.3)//33
    (20.29 0.39 0.54)
    (20.29 3.31 0.54)//35
    (21.74 0.39 0)
    (21.74 3.31 0)
    (21.74 0.39 0.54)
    (21.74 3.31 0.54)//39
blocks
    hex (0 1 2 3 4 5 6 7) (2 29 5) simpleGrading (1 1 1)
    hex (1 8 9 2 10 11 12 13) (10 29 3) simpleGrading (1 1 1)
    hex (2 9 14 15 13 12 16 17) (10 4 3) simpleGrading (1 1 1)
    hex (10 11 12 13 5 18 19 6) (10 29 2) simpleGrading (1 1 1)
    hex (8 20 21 9 18 22 23 19) (182 29 5) simpleGrading (1 1 1)
    hex (20 24 25 21 26 27 28 29) (10 29 3) simpleGrading (1 1 1)
    hex (21 25 30 31 29 28 32 33) (10 4 3) simpleGrading (1 1 1)
    hex (26 27 28 29 22 34 35 23) (10 29 2) simpleGrading (1 1 1)
    hex (24 36 37 25 34 38 39 35) (14 29 5) simpleGrading (1 1 1)
edges
boundary
    box
        type wall;
        faces
            (0 1 4 5)
            (1 8 10 11)
            (10 11 5 18)
            (8 20 22 18)
            (20 24 26 27)
            (26 27 22 34)
            (24 36 38 34)//floor
            (0 1 2 3)
            (1 8 9 2)
            (2 9 14 15)
            (8 20 21 9)
            (20 24 25 21)
            (21 25 30 31)
            (24 36 37 25)//back
            (3 2 7 6)
            (14 15 16 17)
            (13 12 6 19)
            (9 21 23 19)
            (30 31 32 33)
            (29 28 23 35)
            (25 37 35 39)//top
            (2 15 13 17)
            (13 12 16 17)
            (12 16 14 9)//inlet1
            (21 31 33 29)
            (29 28 32 33)
            (25 30 32 28)//inlet2
    symmetry
        type symmetryPlane;
        faces
            (4 5 6 7)
            (5 18 19 6)
            (18 22 23 19)
            (22 34 35 23)
            (34 38 39 35)
    doorin
        type patch;
        faces
      (0 3 4 7)
    doorout
        type patch;
        faces
          (36 37 38 39)
mergePatchPairs
flowwwww is offline   Reply With Quote
[Gmsh] unwanted defaultFaces after exporting to foam 5.0 deepbandivadekar OpenFOAM Meshing & Mesh Conversion 8 July 3, 2018 16:37
[Commercial meshers] How to get rid of internal walls (surfaces)? bmikuz OpenFOAM Meshing & Mesh Conversion 17 December 5, 2013 15:24
How can I get rid of defaultFaces in o folder? AbbasRahimi OpenFOAM Pre-Processing 0 February 7, 2013 14:03
How to get rid of the defaultFaces, Courant number diverge. liguifan OpenFOAM Running, Solving & CFD 1 April 30, 2011 23:13
[Gmsh] How to get rid of the defaultFaces liguifan OpenFOAM Meshing & Mesh Conversion 0 April 30, 2011 22:53
