[Other] Mesh Object with Hole
Old   July 13, 2017, 05:32
Default Mesh Object with Hole
Ashish Vinayak
ashish.vinayak is on a distinguished road
Hello everyone,
I am trying to mesh an object with a cavity using Salome, and I would like to define the boundaries for OpenFOAM.
I have created the mesh using the Body Fitting Algorithm since this is ideal for my purposes (I am constrained to use structured grids thus cannot use NetGEN). After creating the mesh, I need to now select the boundaries. First I created boundary elements using Modifications -> Create boundary elements. This results in the creation of multiple- faces on the surface, which can then be selected using Mesh -> Create Group -> Faces.
However, since there are so many faces, I have to use Manual Edition to add each of them for each boundary group that I define (see image -> light blue represents face element being selected, yellow is all the elements currently selected using Manual Edition, Dark blue is a separate region of the mesh)
I know that the usual method is to create boundary face groups in the GEOMETRY module before meshing, however this does not work for my purpose.
My question is then: is there a way to select multiple elemental faces on a surface with some kind of multi-selection tool or filter. I cannot seem to find it ! Please help.
Last edited by ashish.vinayak; July 13, 2017 at 06:59. Reason: clearer understanding
ashish.vinayak is offline   Reply With Quote
mesh, multiregion, salome
[Other] Can't grow prism mesh off a Wrap-type object using zone-specific growth option Flashfake ANSYS Meshing & Geometry 0 July 23, 2016 03:47
Can't grow prism mesh off a Wrap-type object using zone-specific growth option Flashfake FLUENT 0 July 23, 2016 02:33
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Manually entering fvSchemes information into mesh object jans OpenFOAM Programming & Development 1 October 8, 2014 07:26
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
