[snappyHexMesh] Contact Prevention in SnappyHexMesh
Old   November 16, 2017, 04:32
Default Contact Prevention in SnappyHexMesh
Oliver Herz
herz.o is on a distinguished road
Hi!
Is there an option for a kind of contact prevention in snappyHexMesh?
In Order to prevent local non-manifolds between two boundaries, that a near to each other (although the mesh refinement level should be fine enough to get at least one cell between the boundaries)?
Best Regards
herz.o
herz.o is offline   Reply With Quote
Old   November 16, 2017, 05:12
akidess's Avatar
Anton Kidess
Have SHM refine additionally in tight gaps (gapRefinementLevel or a similar keyword).
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Dynamic contact angle rmousavibt Fluent UDF and Scheme Programming 12 October 31, 2021 22:38
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle FelixJJ FLUENT 2 October 20, 2021 02:39
Urgent Help: Surface Wrapper & Contact Prevention (Crashes using more than one CP) AndreP STAR-CCM+ 7 August 2, 2018 07:04
can anyone help me about the udf of dynamic contact angle in FLUENT? Albert Lee FLUENT 0 July 1, 2018 08:21
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
