[surface handling] surfaceFeatureExtract in Foam Extend 3.2 |
October 7, 2017, 21:08 |
Ashish Kumar
Rep Power: 10 |
I am facing a problem with surfaceFeatureExtract in Foam Extend 3.2
I am using the following command surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/geom.stl But it shows this error --> FOAM FATAL ERROR: Wrong number of arguments, expected 2 found 1 Invalid option: -writeObj |
October 12, 2017, 04:53 |
Katt
Rep Power: 8 |
Have you found out how to do this. I am in need of the same for foam-Extend 1.6. |
October 12, 2017, 08:54 |
Ashish Kumar
Rep Power: 10 |
No, I could not figure it out in foam extend version. But I installed OpenFOAM 4.0 and then got it working with surfaceFeatureExtractDict in system folder and then in the command you have to run surfaceFeatureExtract
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
