October 19, 2017, 04:35 |
Inclined mesh generation
Asmaa
Rep Power: 10 |
Hi Foamers,
I need to generate an inclined mesh as mentioned in the picture bellow. Is it possible using blockMesh ? Otherwise what do you recommend? Thanks in advance! |
October 19, 2017, 05:34 |
Brian Willis
Rep Power: 15 |
You can quite easily transform or rotate a mesh using rotateMesh or transformPoints. I would make your basic mesh in blockMesh, and then rotate it to whatever angle you require.
October 19, 2017, 05:44 |
Asmaa
Rep Power: 10 |
Thank you for your prompt response,
In fact, I'd already tried to rotate the mesh but i cannot get the desired result as you can see in the picture below |
October 19, 2017, 06:26 |
Brian Willis
Rep Power: 15 |
Hi Asmaa
I guess you would like the orientation of the cell faces to match your example. Perhaps try generate a blockMesh as your background mesh with your desired resolution, then use snappyHexMesh with a block angled at 30˚, such as the example below. |
October 19, 2017, 09:01 |
Asmaa
Rep Power: 10 |
Hi Brian,
This is exactly what I am looking for, how can I do it? Is there any similar tutorial in Openfoam? |
October 20, 2017, 04:30 |
Brian Willis
Rep Power: 15 |
Hi Asmaa
Not sure if there is a tutorial. I will attached the case below for you to have a look. The STL and the background mesh was made in Salome and converted for openFOAM. You can quite easily just use blockMesh instead for the background mesh. InclinedMesh.tar.gz |
October 20, 2017, 05:38 |
Asmaa
Rep Power: 10 |
Ok Brian Thanks for help.
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
[ANSYS Meshing] Question about mesh generation learning | lnk | ANSYS Meshing & Geometry | 2 | July 7, 2012 06:45 |
ISAAC code mesh generation | morteza08 | Main CFD Forum | 0 | June 15, 2012 09:26 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
General questions on grid-based computing | Adrin Gharakhani | Main CFD Forum | 21 | June 5, 2000 13:47 |
