[snappyHexMesh] [Problem] Addlayer worsen Mesh quality |
October 25, 2017, 05:16 |
Edoardo
Hi guys.
I'm encountering problems with snappyHexMesh. I'm trying to generate the mesh of a centripetal turbine (scroll and impeller). The snap phase seems ok, the edge are well defined and nothing goes wrong. But when I try to add the boundary layer cells, the edges of the impeller became really bad. I've already tried different edge/surface/region refinements as well as different shrinking parameters. The problem is that the solutor (rhoSimpleFoam) will not do more than 5 iters (I attached the log file). I'm also sure that the problem are these boundary layer cells in the impeller, since if I do not add here the layers the solutor won't have any issues. I attach the images of the problem as well as the dictionaries. I really need help since this is the basis of my master thesis project and it seems I can't find the solution blockMesh.jpg impelleraddLayer.jpg impellersnapped.jpg snappyHexMeshDict.txt logrhoSimpleFoam.txt |
October 26, 2017, 10:27 |
Pascal Balz
Rep Power: 11 |
HI edoardo,
regarding your solver crash: this could either be due to bad boundary conditions or a really bad mesh/wrong fvSchemes. Could you please post the output for Code:
checkMesh -constant -allGeometry Layer generation with snappyHexMesh is really a pain in the ass for propeller geometries. The edges will most times look like yours and layers will likely collapse at the trailing edge. Thats due to the algorithm and I don't know a solution to that. What you should do: - post the log file of snappyHexMesh so that we can see whats going on there - some changes in snappyHexMeshDict: Code:
maxLocalCells: highly increase this value as it will likely stop any refinement steps and layer additions. maxGlobalCells: increase this one too. nCellsBetweenLevels: 3 or more. nLayerIter: increase this value up to 200, start with 50 Most likely your mesh quality settings are to strict for generating the layers. Try setting the following values: maxNonOrtho 75; maxInternalSkewness 10; maxConcave 180; minVol 1e-20; minTetQuality -1e30; minTwist -1;
Regards, Pascal |
addlayers, addlayerscontrols, snappy, snappyhex, snappyhexmesh |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[snappyHexMesh] Improving mesh quality + inlet too coarse | MartinBlx | OpenFOAM Meshing & Mesh Conversion | 5 | August 2, 2015 22:09 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
