[mesh manipulation] refineMesh on complex geometry |
November 4, 2017, 17:19 |
Luis Eduardo
I'm working with an optimization of source terms' location problem, my case involves changing the coordinates of such source terms (between 20~50 sources) on each optimizations step. Until now I was using the following sequence: 1- Get coordinates from optimizer; 2- Generate mesh and refine it in the region where the source term will be inserted using snappyHexMesh; 3- Run topoSet and run the simulation. It worked fine for a test case, but as this scale up (regarding mesh size and complexity) it would be unpractical to re-mesh everything on every optimization loop... I have researched a little and found refineMesh, but I'm not sure if it would be a much faster option. My idea with it is to use SHM to generate the starting mesh and then refine the source term regions on each step of the optimization loop. Do you have any experience with it? Does it seem to be a good option? Is there another better option? I'm using OF4.1. Kind regards, Luis |
refinemesh, snappyhexmesh |
Solving complex geometry with compressible flow | gfoam | FLUENT | 1 | May 19, 2017 14:56 |
Meshing in a complex geometry | Jay_upd | Mesh Generation & Pre-Processing | 0 | February 20, 2015 10:16 |
[ICEM] Complex Geometry for Hex Mesh | smoerebroet | ANSYS Meshing & Geometry | 0 | January 9, 2015 15:21 |
plane cutting complex geometry in the middle | Lilly | FLUENT | 0 | July 27, 2011 09:01 |
How to construct complex 3D geometry using GAMBIT? | Feng | FLUENT | 5 | October 11, 2005 04:13 |
