[snappyHexMesh] SnappyHexMesh on multi-STL geometry in foam extend
Old   April 12, 2016, 21:41
Default SnappyHexMesh on multi-STL geometry in foam extend
Florian Nguyen
Awak is on a distinguished road
Hello friends,
Previously I used OpenFOAM3.0+ to generate a mesh based on 12 separate STL files (the different surfaces that define my patches). In OF30+, the procedure is quite straightforward:
blockMesh (container box for the STL geometry)
surfaceFeatureExtractDict (extract surface features from STL files)
snappyHexMesh (generate a mesh with patches)
The problem is that I now need to switch to foam-extend, and the same procedure does not apply. The surfaceFeatureExtract requires to specify a surface and an "output set", according to the following error I get:
Usage: surfaceFeatureExtract <surface> <output set> [-DebugSwitches key1=val1,key2=val2,...] [-DimensionedConstants key1=val1,key2=val2,...] [-InfoSwitches key1=val1,key2=val2,...] [-OptimisationSwitches key1=val1,key2=val2,...] [-Tolerances key1=val1,key2=val2,...] [-case dir] [-deleteBox ((x0 y0 z0)(x1 y1 z1))] [-dumpControlSwitches] [-includedAngle included angle [0..180]] [-minElem number of edges in feature] [-minLen cumulative length of feature] [-noFunctionObjects] [-set input feature set] [-subsetBox ((x0 y0 z0)(x1 y1 z1))] [-help] [-doc] [-srcDoc]
--> FOAM FATAL ERROR:
Wrong number of arguments, expected 2 found 0
FOAM exiting
If any of you guys ever used foam-extend for such purposes, could you please explain to me what this "output set" is?
Any help would be deeply appreciated, thanks for your time guys,
Florian
Awak is offline   Reply With Quote
Old   May 18, 2017, 02:27
Deepa Vedartham
Deepacfd is on a distinguished road
Hi
I am facing a similar problem. Have you found the solution yet?
Deepacfd is offline   Reply With Quote
Old   May 18, 2017, 21:24
Antimony is on a distinguished road
Is it not the name of the output .eMesh file?
This might be similar to the surfaceFeatureExtract utility that was present in OF2.1, before it was changed to a dictionary based version in OF2.2
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   December 20, 2017, 15:05
Default snappy problem
Sam
anufagbemi is on a distinguished road
Hey guys,
Please any solution to the problem? I use foam-extend 4, and it seems that foam-extend doesn't work with snappyHexMesh.
The error I'm getting, first of all it tells me that "meshQualityDict" cannot be read because
Unknown functionEntry 'includeEtc'
that was easy to correct. but now it now says that
keyword debug is undefined in dictionary "$WM_PROJECT_USER_DIR/FluidSolidInteraction/run/fsiFoam/proj/system/snappyHexMeshDict"
Please if any of you have been able to find a solution for this, please let me know.
Sam
anufagbemi is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 07:49
[Salome] Salome import "Cannot find file "points" in directory..." mismichael OpenFOAM Meshing & Mesh Conversion 5 June 22, 2019 02:56
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
[snappyHexMesh] What types of stl files are needed in snappyhexmesh? phandy OpenFOAM Meshing & Mesh Conversion 1 February 19, 2015 05:36
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
