December 20, 2017, 16:28 |
snappyHexMesh
Sam
Rep Power: 8 |
Hello guys,
Please has anyone been able to run snappyHexMesh on any foam-extend platform? I ran the same case on openFoam 5.x and foam-extend 4.0 and it works very smoothly on 5.x, however when I tried running the exact same case on foam-extend, i keep getting this error. Code:
--> FOAM FATAL IO ERROR: keyword debug is undefined in dictionary "$WM_PROJECT_USER_DIR/FluidSolidInteraction/run/fsiFoam/Stanproj/system/snappyHexMeshDict" file: "$WM_PROJECT_USER_DIR/FluidSolidInteraction/run/fsiFoam/Stanproj/system/snappyHexMeshDict from line 18 to line 310. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 395. FOAM exiting Thanks Samuel |
December 21, 2017, 05:11 |
Canakkale Dardanelspor
Rep Power: 13 |
Have a look at snappyHexMeshDict examples in foam-extend. There most certainly be subtle differences in the dictionary entries of each version. Add the missing entries, which seems to be 'debug' in this particular example, and all will be well. :]
If the problem is more elaborate, you may first need to provide more complete picture of your problem. The following thread might give some insight regarding this: Guide: How to ask a question on the forums |
December 29, 2017, 21:15 |
Re:
Sam
Rep Power: 8 |
Thank you that useful information. Specifically I am trying to carry out fsi simulations with fsiFoam based on real porous media image from mct scans. I used snappyHexMesh separately for both the fluid and solid cases.
Since I am simulating for solid deformation and fluid flow, I need both the solid and fluid domains coupled together. I tried to make both of them, inversions of the other hence giving them a common interface. The fluidDomain.stl is the primary file. I got the solid by using the same exact snappyHexMeshDict file as the fluid and only changed the Code:
locationInMesh Hence solid boundaries are derived from the originally run blockMesh. The only problem I have now is that I need the interface of the solid whose boundaries are now hanging kind of hanging, in order to set the faceZones. i get this error when I run the setSet command for the solid. Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 --> FOAM FATAL ERROR: Error in point ordering: mixed used and unused points at the end of point list. Last used point: 5683 (0.00210709 0.00152491 0.00154834) First unused point: 5684 (0.00210875 0.00152584 0.00154927) and point 5684 (0.00210875 0.00152584 0.00154927) is used by a live face. Face 14 4(5684 744814 829036 745102) with points 4((0.00210875 0.00152584 0.00154927) (0.00210916 0.00152545 0.00154757) (0.00210916 0.00152414 0.00154757) (0.00210916 0.00152414 0.00154888)) Face 16 4(5684 745107 829039 744814) with points 4((0.00210875 0.00152584 0.00154927) (0.00211046 0.00152545 0.00154888) (0.00211046 0.00152545 0.00154757) (0.00210916 0.00152545 0.00154757)) Face 19 4(5684 745102 829040 745107) with points 4((0.00210875 0.00152584 0.00154927) (0.00210916 0.00152414 0.00154888) (0.00211046 0.00152414 0.00154888) (0.00211046 0.00152545 0.00154888)) Face 17831 4(5684 745108 829047 745107) with points 4((0.00210875 0.00152584 0.00154927) (0.00210917 0.00152673 0.00154885) (0.00211 0.00152719 0.00154931) (0.00211046 0.00152545 0.00154888)) Face 17832 4(5684 745107 829365 745109) with points 4((0.00210875 0.00152584 0.00154927) (0.00211046 0.00152545 0.00154888) (0.00211011 0.00152577 0.0015505) (0.00210925 0.00152534 0.00155006)) Face 1803653 4(5684 744814 829037 745106) with points 4((0.00210875 0.00152584 0.00154927) (0.00210916 0.00152545 0.00154757) (0.00210752 0.00152578 0.00154789) (0.00210792 0.00152538 0.00154879)) Face 1803654 4(5684 745106 829038 745102) with points 4((0.00210875 0.00152584 0.00154927) (0.00210792 0.00152538 0.00154879) (0.00210748 0.00152449 0.0015492) (0.00210916 0.00152414 0.00154888)) Face 1803658 4(5684 744814 829042 745108) with points 4((0.00210875 0.00152584 0.00154927) (0.00210916 0.00152545 0.00154757) (0.00210875 0.00152712 0.00154793) (0.00210917 0.00152673 0.00154885)) Face 1804364 4(5684 745109 829362 745102) with points 4((0.00210875 0.00152584 0.00154927) (0.00210925 0.00152534 0.00155006) (0.00210887 0.00152418 0.00155049) (0.00210916 0.00152414 0.00154888)) Done. From function void polyMesh::initMesh() in file meshes/polyMesh/polyMeshInitMesh.C at line 170. FOAM aborting Aborted (core dumped) Attached is the image of both phases for fluid and solid. Please can you help me to map those interface points for the solid. Thanks Sam |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 11:55 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
