Benjamin
Rep Power: 12 ![]() |
Hey everyone
I'm setting up a case where I have an inner volume (cylinder) that is rotating and an outer volume that is stationary ("cylinder with a hole"). Now I understand that at the boundaries, I need cyclicAMI patches to couple the rotating and stationary volumes (see attached image). What I want to do is define the inner volume, define the boundary surface. Then define the outer volume and its boundary surface (which is located at the same coordinates). What I'm struggling with is how I can define the AMI patches (which are at the same location) corresponding to each volume (gmsh). What I've been doing so far is setting the 2 AMI patches slightly apart, but isn't it possible to have them on the same location? Any help would be greatly appreciated! Ben Start of simple geo-File: Code:
Point(1) = {0, 0, 0, 1}; Point(2) = {2, 0, 0, 1}; Point(3) = {-2, 0, 0, 1}; Point(4) = {0, 0, 2, 1}; Point(5) = {0, 0, -2, 1}; Circle(1) = {4, 1, 3}; Circle(2) = {3, 1, 5}; Circle(3) = {5, 1, 2}; Circle(4) = {2, 1, 4}; Point(6) = {3, 0, 0, 1}; Point(7) = {-3, 0, 0, 1}; Point(8) = {0, 0, 3, 1}; Point(9) = {0, 0, -3, 1}; Circle(5) = {8, 1, 7}; Circle(6) = {7, 1, 9}; Circle(7) = {9, 1, 6}; Circle(8) = {6, 1, 8}; Line(9) = {4, 8}; Line(10) = {3, 7}; Line(11) = {5, 9}; Line(12) = {2, 6}; Line Loop(13) = {5, -10, -1, 9}; Plane Surface(14) = {13}; Line Loop(15) = {8, -9, -4, 12}; Plane Surface(16) = {15}; Line Loop(17) = {3, 12, -7, -11}; Plane Surface(18) = {17}; Line Loop(19) = {2, 11, -6, -10}; Plane Surface(20) = {19}; Extrude {0, 1, 0} { Surface{16}; } Extrude {0, 1, 0} { Surface{14}; } Extrude {0, 1, 0} { Surface{18}; } Extrude {0, 1, 0} { Surface{20}; } Physical Surface("wallss") = {51, 29, 81, 103, 108, 20, 64, 14, 42, 16, 18, 86}; Physical Surface("ami2") = {59, 95, 37, 73}; Physical Volume("stator") = {2, 4, 3, 1}; //rotor Point(110) = {1.99, 0, 0, 1}; Point(111) = {-1.99, 0, 0, 1}; Point(112) = {0, 0, 1.99, 1}; Point(113) = {0, 0, -1.99, 1}; Circle(109) = {112, 1, 111}; Circle(110) = {111, 1, 113}; Circle(111) = {113, 1, 110}; Circle(112) = {110, 1, 112}; Line Loop(113) = {109, 110, 111, 112}; Plane Surface(114) = {113}; Extrude {0, 1, 0} { Surface{114}; } Physical Surface("wallsr") = {114, 136}; Physical Surface("ami1") = {123, 135, 131, 127}; Physical Volume("rotor") = {5}; Last edited by Benji; January 16, 2018 at 01:39. |
#2 | |
Arash
Rep Power: 9 ![]() |
Did you manage to solve this? And one more question, does having a gap between rotor/stator causes any problem in your simulation (as long as the gap is less than some threshold)? Best, Arash |
mapField error | rvl565 | OpenFOAM Pre-Processing | 1 | September 6, 2018 16:13 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
[Gmsh] How does Gmsh deal with overlap boundaries? | yuhai | OpenFOAM Meshing & Mesh Conversion | 1 | April 24, 2009 13:34 |
