[Commercial meshers] Visualizing mesh from Numeca to OpenFoam /Paraview |
jorge rodriguez
Rep Power: 17 ![]() |
Hi all,
I used to work with Finemarine from Numeca and used one the tools to export the mesh to open foam extension. I got these files from the exporting option. boundary faces neighbour owner points It might be easy for an Openfoam user to read this files and visualize in paraview but I dont have much clue about it. In my case I'm not an expert so I'm asking for help in this forum if there is a process to follow. Could you please be o help in this task ? Kind Regards |
I would suggest some reading of the user guide. In particular for your problem I refer to the chapter 4: case file structure. But it may make more sense if you run at least one tutorial from chapter 2. Regards, Tom |
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM | nsf | OpenFOAM Meshing & Mesh Conversion | 86 | February 8, 2023 10:30 |
[Commercial meshers] About the Commercial and Closed Source Meshers discussed here | wyldckat | OpenFOAM Meshing & Mesh Conversion | 3 | July 22, 2020 22:09 |
[Commercial meshers] OpenFoam Mesh to Fluent Mesh in parallel case | DominicTNC | OpenFOAM Meshing & Mesh Conversion | 3 | November 22, 2017 09:19 |
[Salome] Mesh conversion Salome to OpenFOAM | VMartinez | OpenFOAM Meshing & Mesh Conversion | 11 | April 21, 2014 02:54 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
