[blockMesh] blockMesh (?): single impeller channel |
April 7, 2018, 12:03 |
Nejc
Rep Power: 9 |
Hello.
Please see the attached image. It is a single channel of a centrifugal impeller, simplified to have infinitely thin blades. There are cyclic boundary conditions on wedge sides on inlet (two blue blocks) and outlet (red block) and MRF zone between inlet and outlet (yellow block). I (again) have huge problems with mesh generation: blockMesh:
snappyHexMesh / cfMesh
SALOME
It is important to me that mesh creation is as fast as possible but even more that it is reliable. I'm trying to run a large number of similar cases with geometry generated by optimization algorithm from an external script. If anyone has any experience or ideas with this kind of problems I'll be very happy to listen Thank you! |
Question on the boundary condition for open channel flow, please help! | ripperjack | OpenFOAM Running, Solving & CFD | 0 | September 13, 2013 11:44 |
Volute outlet flow into impeller inlet | Anthony_impeller | CFX | 4 | December 13, 2011 16:17 |
[ICEM] Blocking of impeller single blade sector (MRF) | delaneyluke | ANSYS Meshing & Geometry | 1 | May 6, 2011 09:28 |
tecplot 3D velocity contours inside a channel | vetnav | Tecplot | 4 | July 14, 2010 20:03 |
About Cooling channel | alefem | FLOW-3D | 1 | May 28, 2010 11:15 |
