[mesh manipulation] stitchMesh : duplicate point
Like Tree1Likes
  • 1 Post By dhruv
Old   February 21, 2011, 10:36
Default stitchMesh : duplicate point
Nolwenn
Nolwenn is on a distinguished road
Hello everybody,
I have a problem using stitchMesh utility. When I want to stitch two interfaces i have a duplicate point error :
Duplicate point found in cut face. Error in the face cutting algorithm for global face 4(53292 53293 54193 54192) local face 4(0 1 2 3)
Slave size: 240 Master size: 917 index: 0.
Face: 10(53292 55407 55408 55092 55165 55164 55163 55166 54193 54192)
I can't find the answer on previous threads...
Nolwenn
Nolwenn is offline   Reply With Quote
Old   October 4, 2011, 22:25
HD
Rebecca513 is on a distinguished road
Hi Nolwenn,
I also got this error message. Have you figured out the problem? Mine two patches should be identical, I don't know where goes wrong...
Thank you!
Best,
Hang
Rebecca513 is offline   Reply With Quote
Old   October 10, 2011, 05:09
Default stitchMesh
supercommandodhruv
dhruv is on a distinguished road
Hi Rebecca and Nolwenn,
I am having the same problem. Did you figure out a solution? I read on the forum, we should use a -perfect flag for stitchMesh, but when i used it, I got the following error message.
--> FOAM FATAL ERROR:
Points on patch sides do not match to within tolerance 7.40161e-06
From function perfectInterface::setRefinement(polyTopoChange& ref) const
in file perfectInterface/perfectInterface.C at line 220.
FOAM exiting
My geometry is like a big block with two rectangular holes, where I am trying to insert via mergeMesh and stitchMesh, two solid rectangular blocks having the same dimensions like the holes.
Thanks,
Dhruv.
pepe.aero likes this.
dhruv is offline   Reply With Quote
Old   October 10, 2011, 11:44
HD
Hi Dhruv,
the -perfect flag actually worked for me. Are the two patches you are working on 100% the same? Maybe you can try other flags?
Best,
Old   May 15, 2013, 10:57
Ignacio
ignacio is on a distinguished road
Did anybody find the solution for this?
I also get Duplicated Points and can't figure out how to get rid of them.
Thanks a lot!
ignacio is offline   Reply With Quote
Old   November 12, 2013, 06:09
pepe.aero is on a distinguished road
Hi Dhruv,
I have right now the same problem trying to merge a rectangular block (1) into a mesh with a rectangular hole (2).
Bounding boxes of block (1) and hole (2) are identical, but points and faces at the interface are different.
The executed command is the following:
stitchMesh -overwrite -perfect INTERFACE defaultFaces
Did you find out a solution for the quoted issue?
Thanks,
Dhruv.
The error reported in my case is the following:
Points on patch sides do not match to within tolerance 1.45655e-05
FOAM exiting
Thanks for your support,
Best regards,
Andrea
pepe.aero is offline   Reply With Quote
Old   March 13, 2014, 05:47
Albrecht vBoetticher
vonboett is on a distinguished road
I get:
--> FOAM FATAL ERROR: Duplicate point found in cut face. Error in the face cutting algorithm for global face
when using stitchMesh. The interfaces are the same but with different resolution and complex cells. Any hints or maybe improvements with OF 2.3 ?
vonboett is offline   Reply With Quote
Old   February 1, 2016, 08:53
Lisa
Lisl is on a distinguished road
I know it's been quite a while since this post was active but did you solve the Problem?
I'm having exactly the same Problem and can't find an answer..
Thanks!!
Lisl is offline   Reply With Quote
Old   February 1, 2016, 11:47
Ignacio
Try increasing a little bit the tolerance, that worked for me.
I have also heard that performing operations such as stitching in binary might also help since it will reduce roudn off arithmetic errors
Old   February 1, 2016, 14:51
Lisa
Thanks for your quick answer!
okay that's what i thought too but where can i change that?
Do i Need something like a tolerance dict?
Old   January 19, 2017, 14:15
Default stitchMesh -perfect
  #11
Metternich is on a distinguished road
I want to merge a mesh to tranlated version of himself with stitchMesh -perfect.
The Mesh on the surfaces are exactly the same (i see in paraview), but i got the dam error "Points on patch sides do not match with ..."
Why??
I am very desperated. Can someone tell me whats going on? Can i force him to stitch the meshes cause i know, they are the same.
Metternich is offline   Reply With Quote
Old   April 23, 2018, 20:26
behrouz_Beh is on a distinguished road
I know this is an old thread but for future use, I mention my experience for this error.
I had the same error with my blockMesh. In my case, I did not define the edges well . After well defining the edges ( for circle in geometry) the problem was solved.
Hope it helps.
behrouz_Beh is offline   Reply With Quote
duplicate point, stitchmesh
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
Duplicate Point found in cut face. Ankit.Dave OpenFOAM 1 February 6, 2020 08:59
[mesh manipulation] stitchMesh: multiple meshes GerhardHolzinger OpenFOAM Meshing & Mesh Conversion 3 August 25, 2017 12:43
[blockMesh] Trouble with MergePatchPairs: Duplicate Point Found in Cut Face dancfd OpenFOAM Meshing & Mesh Conversion 4 March 13, 2014 03:01
[mesh manipulation] stitchMesh Dublicate point ... besto OpenFOAM Meshing & Mesh Conversion 1 October 4, 2011 21:48
