[Other] Mesh-Morphing with dynamicMotionSolverFvMesh
Like Tree2Likes
  • 2 Post By CFD-Henning
Old   March 15, 2018, 07:33
Default Mesh-Morphing with dynamicMotionSolverFvMesh
CFD-Henning's Avatar
Henning Kuchenbuch
CFD-Henning is on a distinguished road
Hey all,
I'm simulating a floating monopile in a numerical wave tank (to extract its heave- and pitch-motion in different sea states). Therefore I'm using OF-1606+ and waves2Foam with dynamic mesh motion. Below is a coarse example of my mesh.
Currently I'm struggeling with a mesh morphing issue:
As you can see, there isn't much space between the pile and the bottom wall, so the mesh motion parameters in this direction have to be chosen very precisely.
With the dynamicMotionSolverFvMesh I can define different parameters for this in the dynamicMeshDict:
|  \\    /   O peration     | Version:  v1606+                                |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      motionProperties;
dynamicFvMesh       dynamicMotionSolverFvMesh;
motionSolverLibs   ("libsixDoFRigidBodyMotion.so");
solver             sixDoFRigidBodyMotion;
diffusivity     quadratic inverseDistance 0.2 ( interface );
sixDoFRigidBodyMotionCoeffs
    report          on;
    reportToFile    on;
    solver
        type Newmark;
   //accelerationDamping 0.9;
    patches         (interface);
    innerDistance   0.01;
    outerDistance   0.2;
    mass            15.7;
    centreOfMass    (0 0 0.298);
    momentOfInertia (6.34 6.34 2.93);
    constraints
        xAxis
            sixDoFRigidBodyMotionConstraint axis;
            axis                (0 1 0);
    LineConstraint
        sixDoFRigidBodyMotionConstraint   line;
        direction          (0 0 1);
I found out, that the corresponding parameters are: diffusivity (diffusion of the mesh motion through the domain) and the inner- and outer distance (def. of area of mesh motion)
I came up with some issues and questions, which google could not answer and I hope some of you can:
  1. The diffusion distance parameter is not working in my case, so only the inner-/outer distance parameters have influence. But I want to manipulate the diffusivity mode. What am I doing wrong?
  2. What's the difference between the diffusivity and inner-/outer distance parameters in term of the diffusion distance? In other words, if I'm defining a diffusion distance in diffusivity, why do I need another definition in inner-/outer distance?
  3. I want to define different mesh motion distances to the directions (so I can set up just 20cm to the bottom, and way more to the sides). Is it possible to define such a distinction? (not in inner-/outer distance, bc. OF demands a scalar)
  4. Biggest issue: I cannot define exactly the distance from the pile bottom to the domain bottom (20cm), bc. OpenFOAM crashes in < 1sec. However, I can define a bit less or more (10cm or 30cm) and this results either in a too big compression of certain cells in this area (10cm) or in an exceedence of the bottom cells out of the domain (30cm) -> both crash. If I could define 20cm, the mesh morphing should perfectly act in this area, but why is this crashing even before some bigger motion occured?
So i would really appreciate any hint to any of these questions.
Henning
CFD-Henning is offline   Reply With Quote
Old   May 12, 2018, 07:20
Smile my investigations
Henning Kuchenbuch
For completeness, if s/o stumbles over the same problems, this i what I found out:
1.) In OF1606+, the diffusion parameter is not looked up, when the solver initializes. As you can see below in sixDoFRigidBodyMotionSolver.H, only "di_" and "do_" matter.
It seems that you cannot decide how deformation is diffused through the mesh (it is a cosine-function, as in point 3 pointed out).
        Class sixDoFRigidBodyMotionSolver Declaration
class sixDoFRigidBodyMotionSolver
    public displacementMotionSolver
    // Private data
        //- Six dof motion object
        sixDoFRigidBodyMotion motion_;
        wordReList patches_;
        //- Patches to integrate forces
        const labelHashSet patchSet_;
        //- Inner morphing distance (limit of solid-body region)
        const scalar di_;
        //- Outer morphing distance (limit of linear interpolation region)
        const scalar do_;
        //- Switch for test-mode in which only the
        //  gravitational body-force is applied
        Switch test_;
        //- Reference density required by the forces object for
        //  incompressible calculations, required if rhoName == rhoInf
        scalar rhoInf_;
        //- Name of density field, optional unless used for an
        //  incompressible simulation, when this needs to be specified
        //  as rhoInf
        word rhoName_;
        //- Current interpolation scale (1 at patches, 0 at distance_)
        pointScalarField scale_;
        //- Current time index (used for updating)
        label curTimeIndex_;
    // Private Member Functions
        //- Disallow default bitwise copy construct
            const sixDoFRigidBodyMotionSolver&
        //- Disallow default bitwise assignment
        void operator=(const sixDoFRigidBodyMotionSolver&);
public:
    //- Runtime type information
    TypeName("sixDoFRigidBodyMotion");
    // Constructors
        //- Construct from polyMesh and IOdictionary
            const polyMesh&,
            const IOdictionary& dict
    //- Destructor
    ~sixDoFRigidBodyMotionSolver();
    // Member Functions
        //- Return point location obtained from the current motion field
        virtual tmp<pointField> curPoints() const;
        //- Solve for motion
        virtual void solve();
        //- Write state using given format, version and compression
        virtual bool writeObject
            IOstream::streamFormat fmt,
            IOstream::versionNumber ver,
            IOstream::compressionType cmp
        ) const;
        //- Read dynamicMeshDict dictionary
        virtual bool read();
2.) See point 1.
3.) The mesh motion is diffused isotropic through the mesh. You can check this in the according function in sixDoFRigidBodyMotionSolver.C, where the relative distance between di and do is calculated (1 to 0) and put into a cosine function.
If anybody has enough C++-skills to improve this code in such a way that one can set up a three-dimensional vector for di and do and the solver calculates the mesh motion direction-dependent, I would really appreciate it. I could not figure out, how to address vectorial objects in C++ .
    // Calculate scaling factor everywhere
        const pointMesh& pMesh = pointMesh::New(mesh);
        pointPatchDist pDist(pMesh, patchSet_, points0());
        // Scaling: 1 up to di then linear down to 0 at do away from patches
        scale_.internalField() =
            min
                max
                    (do_ - pDist.internalField())/(do_ - di_),
                    scalar(0)
                scalar(1)
        // Convert the scale function to a cosine
            min
                max
                    0.5
                  - 0.5
                   *cos(scale_.internalField()
                   *Foam::constant::mathematical::pi),
                    scalar(0)
                scalar(1)
        pointConstraints::New(pMesh).constrain(scale_);
        scale_.write();
4.) Primarily, the simulation became much more stable, when I switched most of the div-schemes to Gauss-upwind. Gauss-upwind seems to be "the shit ".
Furthermore, according to snappyHexMesh, increasing the nCellsBetweenLevels from 3 to 10 and reducing all parameters in the snapControls to a minimum helped also a lot.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    limitedGrad     cellLimited Gauss linear 1;
divSchemes
    default          none;
    div(phi,U)       Gauss upwind;
    div(rhoPhi,U)    Gauss upwind; //Gauss linearUpwind grad(U)
    div(phi,alpha)   Gauss upwind; //Gauss vanLeer;
    div(phirb,alpha) Gauss upwind; //Gauss interfaceCompression; Gauss linear; schlechter
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
For me, this subject is closed . Nevertheless I would really appreciate any hint to point 3.
Greetings,
Henning
raj kumar saini and Maxi_Laj like this.
dynamicmotionsolverfvmesh, mesh, morphing, sixdofrigidbodymotion
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) shubham jain ANSYS Meshing & Geometry 1 April 10, 2017 05:03
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 16:59
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
Mesh Morphing in CFX ??? vmlxb6 CFX 10 March 9, 2011 14:59
