[snappyHexMesh] snappyhexmesh error in refinement phase |
May 10, 2018, 18:45 |
Ishan Anjikar
Rep Power: 8 |
Refinement phase
---------------- --> FOAM FATAL ERROR: Point (3.0001 3.0001 0.43) is not inside the mesh or on a face or edge. Bounding box of the mesh-0.003 -0.003 -0.003) (0.003 0.003 0.003) From function static Foam::labelList Foam::refinementParameters::findCells(bool, const Foam:olyMesh&, const pointField&) in file snappyHexMeshDriver/refinementParameters/refinementParameters.C at line 207. FOAM exiting Can someone please tell me why this is happening. Upon checking the stl file, none of the coordinate of the points is bigger than 0.003 in value |
May 11, 2018, 05:04 |
Ricky
Rep Power: 11 |
Hallo,
The error message itself is self explanatory. The point specified in your snappyHexMeshDict is out of the domain that you are trying to mesh --> A typical scaling error . Change the point from (3.0001 3.0001 0.43) to (3e-3 3e-3 0.43e-3). Hope this helps! Regards, Ricky
If it is easy, then something is fishy! |
May 11, 2018, 13:27 |
#3 | |
Ishan Anjikar
Rep Power: 8 |
[snappyHexMesh] creating baffles using snappyHexMesh (for given random shaped surfaces) | ashish.svm | OpenFOAM Meshing & Mesh Conversion | 1 | January 17, 2018 01:24 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] SnappyHexMesh segmentation Fault | nithishgupta | OpenFOAM Meshing & Mesh Conversion | 1 | December 18, 2014 04:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
