[blockMesh] mergePatchPairs reducing a face to less than 3 points |
May 31, 2018, 21:12 |
Andrew O. Winter
Rep Power: 10 |
Hello CFD Online,
I'm running into issues with simple test cases of the mergePatchPairs functionality of the blockMesh utility using identically-sized blocks that have different meshes and trying different ways of organizing 2 - 4 of these blocks. For instance, shown below is an image of a successful example for 3 blocks that works when I use the mergePatchPairs function of the the blockMesh utility (see the blockMeshDict text below the image). blockMeshDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; x1 0.0; x2 10.0; x3 20.0; y1 0.0; y2 10.0; y3 20.0; z1 0.0; z2 10.0; vertices ( //block1 ($x1 $y1 $z1) ($x2 $y1 $z1) ($x2 $y2 $z1) ($x1 $y2 $z1) ($x1 $y1 $z2) ($x2 $y1 $z2) ($x2 $y2 $z2) ($x1 $y2 $z2) //block 2 ($x2 $y1 $z1) ($x3 $y1 $z1) ($x3 $y2 $z1) ($x2 $y2 $z1) ($x2 $y1 $z2) ($x3 $y1 $z2) ($x3 $y2 $z2) ($x2 $y2 $z2) //block3 ($x1 $y2 $z1) ($x2 $y2 $z1) ($x2 $y3 $z1) ($x1 $y3 $z1) ($x1 $y2 $z2) ($x2 $y2 $z2) ($x2 $y3 $z2) ($x1 $y3 $z2) ); blocks ( hex (0 1 2 3 4 5 6 7) (10 10 10) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (20 20 20) simpleGrading (1 1 1) hex (16 17 18 19 20 21 22 23) (20 20 20) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { type wall; faces ( (0 4 7 3) (16 20 23 19) ); } outlet { type wall; faces ( (9 13 14 10) ); } top { type wall; faces ( (4 5 6 7) (12 13 14 15) (20 21 22 23) ); } bottom { type wall; faces ( (0 1 2 3) (8 9 10 11) (16 17 18 19) ); } right { type wall; faces ( (0 1 5 4) (8 9 13 12) ); } left { type wall; faces ( (19 18 22 23) (17 21 22 18) (11 10 14 15) ); } interface1 { type wall; faces ( (1 5 6 2) ); } interface2 { type wall; faces ( (8 12 15 11) ); } interface3 { type wall; faces ( (3 2 6 7) ); } interface4 { type wall; faces ( (16 17 21 20) ); } ); mergePatchPairs ( (interface1 interface2) (interface3 interface4) ); // ************************************************************************* // Modified blockMeshDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; x1 0.0; x2 10.0; x3 20.0; y1 0.0; y2 10.0; y3 20.0; z1 0.0; z2 10.0; vertices ( //block1 ($x1 $y1 $z1) ($x2 $y1 $z1) ($x2 $y2 $z1) ($x1 $y2 $z1) ($x1 $y1 $z2) ($x2 $y1 $z2) ($x2 $y2 $z2) ($x1 $y2 $z2) //block 2 ($x2 $y1 $z1) ($x3 $y1 $z1) ($x3 $y2 $z1) ($x2 $y2 $z1) ($x2 $y1 $z2) ($x3 $y1 $z2) ($x3 $y2 $z2) ($x2 $y2 $z2) //block3 ($x1 $y2 $z1) ($x2 $y2 $z1) ($x2 $y3 $z1) ($x1 $y3 $z1) ($x1 $y2 $z2) ($x2 $y2 $z2) ($x2 $y3 $z2) ($x1 $y3 $z2) //block4 ($x2 $y2 $z1) ($x3 $y2 $z1) ($x3 $y3 $z1) ($x2 $y3 $z1) ($x2 $y2 $z2) ($x3 $y2 $z2) ($x3 $y3 $z2) ($x2 $y3 $z2) ); blocks ( hex (0 1 2 3 4 5 6 7) (10 10 10) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (20 20 20) simpleGrading (1 1 1) hex (16 17 18 19 20 21 22 23) (20 20 20) simpleGrading (1 1 1) hex (24 25 26 27 28 29 30 31) (10 10 10) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { type wall; faces ( (0 4 7 3) (16 20 23 19) ); } outlet { type wall; faces ( (9 13 14 10) (25 29 30 26) ); } top { type wall; faces ( (4 5 6 7) (12 13 14 15) (20 21 22 23) (28 29 30 31) ); } bottom { type wall; faces ( (0 1 2 3) (8 9 10 11) (16 17 18 19) (24 25 26 27) ); } right { type wall; faces ( (0 1 5 4) (8 9 13 12) ); } left { type wall; faces ( (19 18 22 23) (27 26 30 31) ); } master1 { type wall; faces ( (1 5 6 2) ); } master2 { type wall; faces ( (3 2 6 7) ); } master3 { type wall; faces ( (24 28 31 27) ); } master4 { type wall; faces ( (24 25 29 28) ); } slave1 { type wall; faces ( (8 12 15 11) ); } slave2 { type wall; faces ( (16 17 21 20) ); } slave3 { type wall; faces ( (17 21 22 18) ); } slave4 { type wall; faces ( (11 10 14 15) ); } ); mergePatchPairs ( (master1 slave1) (master2 slave2) (master3 slave3) (master4 slave4) ); // ************************************************************************* // Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.0 Exec : blockMesh Date : May 31 2018 Time : 17:45:08 Host : "n0536" PID : 6021 I/O : uncollated Case : /civil/shared/motley/andrew25/OpenFOAM/5.0/buildings/olaDyMFoam/May29/B0-S0-Unbroken/test2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/civil/shared/motley/andrew25/OpenFOAM/5.0/buildings/olaDyMFoam/May29/B0-S0-Unbroken/test2/system/blockMeshDict" Creating block edges No non-planar block faces defined Creating topology blocks Creating topology patches Creating block mesh topology Check topology Basic statistics Number of internal faces : 0 Number of boundary faces : 24 Number of defined boundary faces : 24 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating polyMesh from blockMesh Creating patches Creating cells Creating points with scale 1 Block 0 cell size : i : 0.5 .. 0.5 j : 0.5 .. 0.5 k : 0.5 .. 0.5 Block 1 cell size : i : 0.25 .. 0.25 j : 0.25 .. 0.25 k : 0.25 .. 0.25 Block 2 cell size : i : 0.25 .. 0.25 j : 0.25 .. 0.25 k : 0.25 .. 0.25 Block 3 cell size : i : 0.5 .. 0.5 j : 0.5 .. 0.5 k : 0.5 .. 0.5 Creating merge patch pairs Adding point and face zones Creating attachPolyTopoChanger --> FOAM FATAL ERROR: Face 56180 reduced to less than 3 points. Topological/cutting error B. Old face: 2(10612 11053) new face: 2(19853 21825) From function void Foam::slidingInterface::coupleInterface(Foam::polyTopoChange&) const in file slidingInterface/coupleSlidingInterface.C at line 1768. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/gscratch/motley/shared/OpenFOAM500/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/gscratch/motley/shared/OpenFOAM500/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" #2 Foam::slidingInterface::coupleInterface(Foam::polyTopoChange&) const in "/gscratch/motley/shared/OpenFOAM500/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so" #3 Foam::polyTopoChanger::topoChangeRequest() const in "/gscratch/motley/shared/OpenFOAM500/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so" #4 Foam::polyTopoChanger::changeMesh(bool, bool, bool, bool) in "/gscratch/motley/shared/OpenFOAM500/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so" #5 Foam::attachPolyTopoChanger::attach(bool) in "/gscratch/motley/shared/OpenFOAM500/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so" #6 ? in "/gscratch/motley/shared/OpenFOAM500/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/bin/blockMesh" #7 __libc_start_main in "/lib64/libc.so.6" #8 ? in "/gscratch/motley/shared/OpenFOAM500/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/bin/blockMesh" Aborted If anyone has any idea as to what happened, I would appreciate your assistance and insight very much! |
June 1, 2018, 04:28 |
Yasasvi Harish Kumar
Rep Power: 8 |
Hey,
I just took a quick look at your blockMeshDict and from what I can see, your slave1 and slave4 patch have two common vertices. But since you've already merged slave1, the vertices are a part of master1. That's why you have that error. Try using another set of vertices with the same coordinates for slave4. |
June 1, 2018, 17:37 |
Andrew O. Winter
Rep Power: 10 |
Hey Yasasvi,
I tried to play with adding even more nodes; however, I think that didn't work because I was using node numbers that were not actually associated with any of my hexes. I don't see how you can avoid having to reuse existing nodes in a 4 block configuration where you have to stitch together the blocks in 4 places and the middle corners present the problem of needing to be used twice as you pointed out where I was using a slave face node more than once, which is of course impossible as you also pointed out. Instead of trying to play with the node and hex configuration, I found that there is a stitchMesh command that I had not tried before, which was perfect for what I was wanting to achieve when trying to combine the 4 hexes in a square pattern. blockMeshDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; x1 0.0; x2 5.0; x3 10.0; y1 0.0; y2 5.0; y3 10.0; z1 0.0; z2 5.0; vertices ( //block1 ($x1 $y1 $z1) ($x2 $y1 $z1) ($x2 $y2 $z1) ($x1 $y2 $z1) ($x1 $y1 $z2) ($x2 $y1 $z2) ($x2 $y2 $z2) ($x1 $y2 $z2) //block 2 ($x2 $y1 $z1) ($x3 $y1 $z1) ($x3 $y2 $z1) ($x2 $y2 $z1) ($x2 $y1 $z2) ($x3 $y1 $z2) ($x3 $y2 $z2) ($x2 $y2 $z2) //block3 ($x1 $y2 $z1) ($x2 $y2 $z1) ($x2 $y3 $z1) ($x1 $y3 $z1) ($x1 $y2 $z2) ($x2 $y2 $z2) ($x2 $y3 $z2) ($x1 $y3 $z2) //block4 ($x2 $y2 $z1) ($x3 $y2 $z1) ($x3 $y3 $z1) ($x2 $y3 $z1) ($x2 $y2 $z2) ($x3 $y2 $z2) ($x3 $y3 $z2) ($x2 $y3 $z2) //duplicates ($x2 $y2 $z1) ($x2 $y2 $z2) ($x2 $y2 $z1) ($x2 $y2 $z2) ); blocks ( hex (0 1 2 3 4 5 6 7) (10 10 10) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (20 20 20) simpleGrading (1 1 1) hex (16 17 18 19 20 21 22 23) (20 20 20) simpleGrading (1 1 1) hex (24 25 26 27 28 29 30 31) (10 10 10) simpleGrading (1 1 1) ); edges ( ); boundary ( inletA { type wall; faces ( (0 4 7 3) ); } inletB { type wall; faces ( (16 20 23 19) ); } outletA { type wall; faces ( (9 13 14 10) ); } outletB { type wall; faces ( (25 29 30 26) ); } topA { type wall; faces ( (4 5 6 7) (12 13 14 15) ); } topB { type wall; faces ( (20 21 22 23) (28 29 30 31) ); } bottomA { type wall; faces ( (0 1 2 3) (8 9 10 11) ); } bottomB { type wall; faces ( (16 17 18 19) (24 25 26 27) ); } rightA { type wall; faces ( (0 1 5 4) (8 9 13 12) ); } rightB { type wall; faces ( (16 17 21 20) (24 25 29 28) ); } leftA { type wall; faces ( (3 2 6 7) (11 10 14 15) ); } leftB { type wall; faces ( (19 18 22 23) (27 26 30 31) ); } masterA { type wall; faces ( (1 5 6 2) ); } masterB { type wall; faces ( (17 21 22 18) ); } slaveA { type wall; faces ( (8 12 15 11) ); } slaveB { type wall; faces ( (24 28 31 27) ); } ); mergePatchPairs ( (masterA slaveA) (masterB slaveB) ); // ************************************************************************* // This result is exactly what I was hoping for and even though it was not achieved purely with the blockMesh command, it gets the job done perfectly and only requires 1 additional step using the stitchMesh command. Thanks again for pointing me in the correct direction to understand why my initial approach would not work! If you know a way to do it with just blockMesh, I would love to know, but for now this is perfect. Best regards, Andrew |
[snappyHexMesh] Layers not growing at all | zonda | OpenFOAM Meshing & Mesh Conversion | 12 | June 6, 2020 11:28 |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 07:05 |
sample utility of OF2.3.1 provides less points | aCFDuser | OpenFOAM Post-Processing | 7 | May 1, 2017 21:25 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
