July 17, 2018, 04:53 |
snappyHexMesh IOstream
Ewan
Rep Power: 9 |
I am trying to run snappyHexMesh having only modified a couple of things in the control Dict to suit my patches but the following error keeps cropping up "keyword meshQualityControls is indefined in dictionary "IOstream"". The 'meshQualityControls' has also been 'castellatedMeshControls' depending on which parts I comment out.
I am working in Docker if that has any effect but I think it is probably me just missing some punctuation somewhere! Please could someone help? (I've had to rename the file to a .txt but if you change it back to .mh it should open!) |
iostream, snappy hex mesh, snappyhexmesh, snappyhexmeshdict |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
Strange Results With snappyHexMesh | calebamiles | OpenFOAM Running, Solving & CFD | 0 | August 14, 2011 16:02 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
