February 3, 2019, 14:01 |
2D polyDualMesh
Reviewer #2
Rep Power: 10 |
I was trying to follow the tutorial of polyDualMesh for 2D application (https://openfoamwiki.net/index.php/PolyDualMesh). However, I always ended with some bizarre mesh near the sharp angle (see attachment). I play around with the angle in combinePatchFaces, but no luck. Thanks, Rdf |
February 19, 2019, 10:36 |
Reviewer #2
Rep Power: 10 |
For the future reference, if you generate the poly mesh directly by gmsh, you can avoid this problem.
[mesh manipulation] problem using polyDualMesh | Rebecca513 | OpenFOAM Meshing & Mesh Conversion | 10 | March 4, 2020 12:53 |
[mesh manipulation] Sharp edge problem on concave patches using polyDualMesh without error | keepfit | OpenFOAM Meshing & Mesh Conversion | 1 | November 25, 2014 14:28 |
[snappyHexMesh] polyDualMesh -- Error | kingmaker | OpenFOAM Meshing & Mesh Conversion | 4 | November 22, 2013 04:33 |
[mesh manipulation] polyDualMesh edges between patches | maninthemail | OpenFOAM Meshing & Mesh Conversion | 1 | May 22, 2012 13:15 |
[mesh manipulation] polyDualMesh and volume calculation... | jbf | OpenFOAM Meshing & Mesh Conversion | 2 | September 15, 2009 18:37 |
