[mesh manipulation] How does fieldToCell work in TopoSet? |
April 15, 2021, 23:41 |
#1 | |
Sunag R A
Rep Power: 6 |
Dear All,
I am working on chtMultiRegionSimpleFoam heat transfer problem. First, I have two regions. Out of which one region named gland is a surface where external temperature parameters are implemented. The temperature consists of zeros and variables. Say our of 1000 faces, 600 are zero temp and 400 are variable temperature. Now, I need to change the BC of this 600 zero temperature. I am trying to use fieldToCell in TopoSet to get faces of these 600 zero temperature and convert into patch using splitMesh. But, I am confused in using fieldToCell. I applied like below. Quote:
But when I run topoSet, it shows as: Cannot read field T from time 0 cellSet field1 now size 0 My question is. 1. Where does the toposet collects this fieldData so that it can create the CellSet. 2. I have a temperature file externally which 0 temp and variable temp. How to use this here? Any leads will be appreciated. Regards, Sunag R A. |
createpatch, field, patch, splitmesh, toposet |
[mesh manipulation] TopoSet cellset is not deleting from stl cellZone | sunagra27 | OpenFOAM Meshing & Mesh Conversion | 0 | March 9, 2021 01:50 |
bug : topoSet STOP RESPONDING while trying to make cellzones near to a surface. | sk11 | OpenFOAM Bugs | 0 | March 1, 2021 11:49 |
Does CX_Interpret_String work in parallel? | 86lolo | Fluent UDF and Scheme Programming | 2 | June 30, 2014 04:36 |
Companies that lease software & hardware for cloud-based work? | Catthan | ANSYS | 0 | June 18, 2014 10:53 |
Do all CFD analysts have to do some hands-on work except PhDs? | e13drd | Main CFD Forum | 2 | March 17, 2014 14:56 |
