[mesh manipulation] splitting patch into two boundary conditions using splitMesh |
September 12, 2018, 17:04 |
Rep Power: 7 |
Dear Foamers;
i have been searching for how to make a slot in a cyclic wall, using bunch of utilities but i didn't succeed so i decided to post a thread here. My problem is that i have two parallel walls, one on top of the other (that 's how i created them the first time for some boundary reasons that i posted before). everything worked perfectly, i could generate a flow and see the animation of the flow in the wind tunnel design. Now i want to made a small open windows (a slot) that connects the flow from the inside of the tunnel to the outside at the entry of the diffuser of inches, to do that i have to make a double slot for my two cyclic walls. I tried TopoSet with boxtocell and patchtoface but it didn't work because i don't want to add nor extract a cell from my mesh since they have flow information that i need, then i found splitMesh in modifyMeshDict since all i want is keep the rest of the boundary condition as a wall, but change a small part of it, to, i don't know yet if zerogradient with zero velocity. But for now im just looking how can i work it out, or anyone has a better idea, utility tool to share with me. FoamFile { version 2.0; format ascii; class dictionary; location "system"; object modifyMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // //Split boundary edge in two: edgesToSplit ( ((1.73 0.87 0) (1.68 0.88 0.1)) ((1.73 0.88 0) (1.68 0.89 0.1)) ); Thank you everyone for the help! |
September 30, 2018, 00:29 |
Amod Kumar
It is difficult to visualize the problem. You might get a help is you explain the problem using a picture/sketch. Regards, Amod |
October 13, 2018, 14:38 |
Rep Power: 7 |
I fixed it! Thank you!
November 21, 2018, 10:17 |
Christian Lackner
Can you explain how you fixed it please?
I have a similar problem. Thank you in advance! |
#mesh #spliting #boundary |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
