[mesh manipulation] splitting patch into two boundary conditions using splitMesh
Like Tree1Likes
  • 1 Post By amod_kumar
Old   September 12, 2018, 17:04
Default splitting patch into two boundary conditions using splitMesh
salomama is on a distinguished road
Dear Foamers;
i have been searching for how to make a slot in a cyclic wall, using bunch of utilities but i didn't succeed so i decided to post a thread here.
My problem is that i have two parallel walls, one on top of the other (that 's how i created them the first time for some boundary reasons that i posted before). everything worked perfectly, i could generate a flow and see the animation of the flow in the wind tunnel design. Now i want to made a small open windows (a slot) that connects the flow from the inside of the tunnel to the outside at the entry of the diffuser of inches, to do that i have to make a double slot for my two cyclic walls.
I tried TopoSet with boxtocell and patchtoface but it didn't work because i don't want to add nor extract a cell from my mesh since they have flow information that i need, then i found splitMesh in modifyMeshDict since all i want is keep the rest of the boundary condition as a wall, but change a small part of it, to, i don't know yet if zerogradient with zero velocity. But for now im just looking how can i work it out, or anyone has a better idea, utility tool to share with me.
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object modifyMeshDict;
//Split boundary edge in two:
edgesToSplit
((1.73 0.87 0) (1.68 0.88 0.1))
((1.73 0.88 0) (1.68 0.89 0.1))
Thank you everyone for the help!
salomama is offline   Reply With Quote
Old   September 30, 2018, 00:29
Amod Kumar
amod_kumar is on a distinguished road
It is difficult to visualize the problem. You might get a help is you explain the problem using a picture/sketch.
Regards,
Amod
salomama likes this.
amod_kumar is offline   Reply With Quote
Old   October 13, 2018, 14:38
I fixed it! Thank you!
Old   November 21, 2018, 10:17
Christian Lackner
ChristianLackner is on a distinguished road
Can you explain how you fixed it please?
I have a similar problem.
Thank you in advance!
ChristianLackner is offline   Reply With Quote
#mesh #spliting #boundary
Centrifugal fan j0hnny CFX 13 October 1, 2019 13:55
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
