November 27, 2018, 19:52 |
Embedded cylindrical mesh
Justine
Rep Power: 7 |
Hi All,
I am trying to model a rotating flap that will be in a dynamic, cylindrical mesh, similar to the attached image from a paper by Schmitt and Elsaesser (2015). I need to embed this into a larger, simpler mesh and eventually connect the two with an arbitrary mesh interface (AMI). First, I tried modeling just a cylinder using blockMesh geometry. This creates some kind of entity that blockMesh using to project vertices and edges onto. I did not totally understand this process, so I modified an existing one that I found as part of a tutorial. Next, I tried to copy this cylinder into my larger domain blockMeshDict file (consisting of standard blocks) knowing that its location would overlap with the rest of the mesh. Upon running blockMesh, I get an error that does not surprise me: "Inconsistent number of faces between block pair 5 and 6", yet I do not know how else to go about this problem. Does anyone know how I can build my domain, and possible get the AMI working so that I can start having the cylinder move with the flap inside? Last edited by JBrake; December 6, 2018 at 20:15. |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 16:59 |
[Commercial meshers] Problems with ANSYS mesh conversion | tdog | OpenFOAM Meshing & Mesh Conversion | 1 | March 31, 2016 17:36 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
