[snappyHexMesh] snappyHexMesh not reading stl file |
November 30, 2018, 16:53 |
Vikram Rajagopalan
Rep Power: 7 |
Trying to mesh the body of some oceanographic instumentation using SHM (basically just a cylinder with tapered edges) and SHM is forming the mesh (no errors) but the object is not in it. I think it could be some problem with my .stl file.
case directory - https://drive.google.com/open?id=1uh...UmBw7kELtI5Idt Last edited by vikramrajagopalan; November 30, 2018 at 20:08. |
November 30, 2018, 20:08 |
Vikram Rajagopalan
Rep Power: 7 |
Solved - was a problem with type of stl file that I was trying to import into snappy.
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
