[Commercial meshers] Garbled of faces etc. after fluentMeshToFoam |
December 19, 2018, 16:05 |
Xiang Zhao
Rep Power: 7 |
Hi, I am using ICEM 19.0 to block my mesh. After I copy the ~.msh file to ubuntu 18.04 and type fluentMeshToFoam, I can get the polyMesh file folder. But when I try to edit some of the files, for instance, faces etc. All are garbled, see the pictures. I try to use uchardet * to get the encoding of the files, these wired files are unknown. I would like to edit these files just with clicking mouse, opening with text editor, typing and closing and saving. Does anyone know how to achieve that?
December 20, 2018, 03:21 |
Xiang Zhao
Rep Power: 7 |
I figure it out. It is the problem with writeFormat in the controlDic. When I change it to ascii, it is OK. Those pictures attached are write in binary format.
fluentmeshtofoam, garbled |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
