[Other] Equal decomposition of cylindrical fluid domain |
January 22, 2019, 09:52 |
Sean Gorry
Rep Power: 8 |
I'm just wondering how I could equally decompose a cylindrical fluid domain so that each processor has the same number of cells. I can quarter the domain using simple but I want to divide it further. The simulation crashes unless each processor has the same number of cells, the picture below is of the YZ plane.
January 23, 2019, 08:16 |
anonymous
Hi!
The simplest if you use scotch. It'll try to reduce the common faces of the proc. regions (smaller processor patches -> less communication between processors) It is easy to use, you only have to specify the number of processors. |
January 23, 2019, 09:50 |
Sean Gorry
Rep Power: 8 |
I tried using scotch but the simulation crashes. The only time the mesh motion solver hasn't crashed is when each processor has the same amount of cells.
simple (1 2 2) Code:
Processor 0 Number of cells = 320640 Number of faces shared with processor 1 = 10736 Number of faces shared with processor 2 = 10736 Number of processor patches = 2 Number of processor faces = 21472 Number of boundary faces = 12320 Processor 1 Number of cells = 320640 Number of faces shared with processor 0 = 10736 Number of faces shared with processor 3 = 10736 Number of processor patches = 2 Number of processor faces = 21472 Number of boundary faces = 12320 Processor 2 Number of cells = 320640 Number of faces shared with processor 0 = 10736 Number of faces shared with processor 3 = 10736 Number of processor patches = 2 Number of processor faces = 21472 Number of boundary faces = 12320 Processor 3 Number of cells = 320640 Number of faces shared with processor 1 = 10736 Number of faces shared with processor 2 = 10736 Number of processor patches = 2 Number of processor faces = 21472 Number of boundary faces = 12320 Number of processor faces = 42944 Max number of cells = 320640 (0% above average 320640) Max number of processor patches = 2 (0% above average 2) Max number of faces between processors = 21472 (0% above average 21472) Time = 0 Processor 0: field transfer Processor 1: field transfer Processor 2: field transfer Processor 3: field transfer End scotch (4 equally weighted processors) Code:
Processor 0 Number of cells = 321064 Number of faces shared with processor 1 = 5353 Number of faces shared with processor 2 = 5336 Number of processor patches = 2 Number of processor faces = 10689 Number of boundary faces = 10773 Processor 1 Number of cells = 319067 Number of faces shared with processor 0 = 5353 Number of faces shared with processor 3 = 5082 Number of processor patches = 2 Number of processor faces = 10435 Number of boundary faces = 10655 Processor 2 Number of cells = 321884 Number of faces shared with processor 0 = 5336 Number of processor patches = 1 Number of processor faces = 5336 Number of boundary faces = 15494 Processor 3 Number of cells = 320545 Number of faces shared with processor 1 = 5082 Number of processor patches = 1 Number of processor faces = 5082 Number of boundary faces = 12358 Number of processor faces = 15771 Max number of cells = 321884 (0.3879741% above average 320640) Max number of processor patches = 2 (33.33333% above average 1.5) Max number of faces between processors = 10689 (35.5526% above average 7885.5) Time = 0 Processor 0: field transfer Processor 1: field transfer Processor 2: field transfer Processor 3: field transfer End |
February 12, 2019, 03:34 |
Zander Meiring
Rep Power: 7 |
Do you have a cyclic domain boundary? If so, it's important to have those two boundaries on the same processor. This can be done with scotch by using the 'singleProcessorFaceSets' option. For example:
FoamFile { version 2; format ascii; class dictionary; object decomposeParDict; } numberOfSubdomains 24; method scotch; singleProcessorFaceSets ( ( cyclic -1 ) ); where cyclic is a faceSet I defined in a topoSetDict: Code:
FoamFile { version 2.0; format ascii; class dictionary; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name cyclic; type faceSet; action new; source patchToFace; sourceInfo { name side1; } } { name cyclic; type faceSet; action add; source patchToFace; sourceInfo { name side2; } } } |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 19:42 |
Floating point exception: Zero divide | liladhar | CFX | 11 | December 16, 2013 04:07 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
