[Gmsh] Version 20 of the bmshb file format to FOAM converter
Old   February 15, 2007, 21:24
Default Version 20 of the bmshb file format to FOAM converter
Takuya OSHIMA
7islands is on a distinguished road
Hi all,
Have anyone tried supporting version 2.0 of the .msh file format in gmshToFoam?
Thanks,
Takuya
7islands is offline   Reply With Quote
Old   February 16, 2007, 00:58
Default OK here's the one (with quick
Takuya OSHIMA
OK here's the one (with quick and dirty hacks of course).
gmshToFoam-20070216.C
Regards,
Takuya
Old   February 16, 2007, 07:32
Default Hi all, I've renamed it to gm
Takuya OSHIMA
Hi all,
I've renamed it to gmsh2ToFoam and posted it on Wiki.
http://openfoamwiki.net/index.php/Contrib_gmsh2ToFoam
Takuya
Old   February 17, 2007, 22:50
Default Hi all, I've made an importan
Takuya OSHIMA
Hi all,
I've made an important fix to the correspondence problem between OpenFOAM cellZone/patch numbering and Gmsh physical/elementary entity tagging.
If there's anyone who have tried the first version could you please try the new version (gmsh2ToFoam-20070218) again.
Thanks,
Takuya
Old   February 19, 2007, 02:55
Default Hi Gmsh users, This time gm
Takuya OSHIMA
Hi Gmsh users,
This time gmsh2ToFoam assigns physical entity names defined by "Physical Surface" and "Physical Volume" gmsh commands (such as "inlet", "outlet", ...) to patches / cellZones / faceZones insted of automatically generated names (such as "patch0", "patch1", ...). This is realized by utilizing one of the new key features in Gmsh 2.0.
This is supposed to be useful especially in practical use and actually is what I really wanted to do through gmsh2ToFoam. For Gmsh 1.x users who don't get what I mean, I've prepared a deteiled example on the Wiki.
Thanks,
Takuya
Old   February 21, 2007, 06:18
Default Thanks for the updates Takuya.
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Thanks for the updates Takuya. I'll give your version a try when I create my next mesh
msrinath80 is offline   Reply With Quote
Old   March 9, 2007, 08:27
Default Hi Marco, Thanks for testing
Takuya OSHIMA
Hi Marco,
Thanks for testing gmsh2ToFoam. Seems that gmsh2ToFoam.C you tested is an old one (maybe the initial version I guess) since the current version gmsh2ToFoam-20070305 (05 Mar 2007) on the Wiki already has the code almost exactly like what you wrote. Further the 20070305 version can assign string labels in $PhysicalNames section as patch names. If you have time to test the version please give it a try.
Takuya
Old   March 9, 2007, 09:13
Default Hi Takuya, I write a small pi
Marco Moscaritolo
mavimo is on a distinguished road
Hi Takuya,
I write a small piece of code to applay $PhysicalNames to patch generated with gmsh2ToFoam, the name of physical surface is saved into physicalNameList variable and after the code apply this name to patch (replace pathc0, patch1, ...). It's so easy to write the code, I don't have my version of gmsh2ToFoam.C file on this PC, sorry, but work with my case (It has not been tested with other models).
Bye
Marco
mavimo is offline   Reply With Quote
Old   March 9, 2007, 09:55
Default Hi, Yes, that's exactly what
Takuya OSHIMA
Yes, that's exactly what I've done in the newest gmsh2ToFoam-20070305 (saving the region numbers and string labels in $PhysicalNames section into arrays and later matching the numbers with the labels). Maybe with your knowledge you can get what I've done as soon as you look into my newest code.
http://openfoamwiki.net/images/e/eb/...0070305.tar.gz
Additionaly, the code also has ability to remove unused points (still experimental though) frequently discussed in the Gmsh mailing list e. g.:
http://www.geuz.org/pipermail/gmsh/2007/002396.html
so that checkMesh test no longer fails even if a .msh file contains such points.
Takuya
Old   March 9, 2007, 10:22
Default Thanks Bya Marco
Marco Moscaritolo
Thanks
Bya Marco
Old   March 9, 2007, 10:23
Default Thanks! Bye Marco
  #11
Marco Moscaritolo
Thanks!
Bye
Marco
Old   March 9, 2007, 17:21
Default I have create a new model with
  #12
Marco Moscaritolo
I have create a new model with gmsh 2.0.4:
// Gmsh project created on Mon Mar 5 14:41:29 2007
nc = 10;
// * Flame plane *
Point(1) = {0,0,0,0.1};
l1[] = Extrude {0,0.035,0} { Point{1}; Layers{nc*3,1}; };
l2[] = Extrude {0,0.008,0} { Point{2}; Layers{nc*1,1}; };
l3[] = Extrude {0,0.017,0} { Point{3}; Layers{nc*1,1}; };
s1[] = Extrude {{0,0,1}, {0,0,0}, Pi/16} {
Line{l1[1]}; Layers{nc*0.5,1}; Recombine;
s2[] = Extrude {{0,0,1}, {0,0,0}, Pi/16} {
Line{l2[1]}; Layers{nc*0.5,1}; Recombine;
s3[] = Extrude {{0,0,1}, {0,0,0}, Pi/16} {
Line{l3[1]}; Layers{nc*0.5,1}; Recombine;
// Uniscle superfici
stot[] = {s1[1], s2[1], s3[1]};
// Le estrudo per creare il volume
Extrude {0,0,0.023} {
Surface{stot[]}; Layers{nc*2,1}; Recombine;
// * wall plane *
Extrude {0,0,0.008} {
Surface{53}; Layers{nc*2,1}; Recombine;
Surface{75}; Layers{nc*2,1}; Recombine;
// * smoke plane *
l4[] = Extrude {0,0.035,0} { Point{37}; Layers{nc*3,1}; };
s4[] = Extrude {{0,0,1}, {0,0,0}, Pi/16} {
Line{l4[1]}; Layers{nc*0.5,1}; Recombine;
Extrude {0,0,0.06} {
Surface{123}; Layers{nc*2,1}; Recombine;
Surface{119}; Layers{nc*2,1}; Recombine;
Surface{97}; Layers{nc*2,1}; Recombine;
// Create a volume
Surface Loop(185) = {139,123,131,140,135};
Volume(186) = {185};
// * Assegnazione nomi *
// Generate surface whit name
Physical Surface("plate") = {123,96,31};
Physical Surface("inlet-flame") = {6};
Physical Surface("inlet-inert") = {10};
Physical Surface("atmosphere") = {14,66,110,153,184,162,140};
Physical Surface("simmetry1") = {139,179,157,114,92,48,70,30};
Physical Surface("simmetry2") = {131,22,40,62,149,171,84,106};
Physical Volume("internalField") = {186};
but when I convert the mesh obtain this error:
.msh file version 2
Found $PhysicalNames section.
Read nVerts:15036
Read nElems:6000
Mapping physical region 2 to Foam physical patch 0
Mapping physical region 1 to Foam physical patch 1
Mapping physical region 4 to Foam physical patch 2
Mapping physical region 3 to Foam physical patch 3
Mapping physical region 6 to Foam physical patch 4
Mapping physical region 5 to Foam physical patch 5
Cells:
total:0
hex :0
prism:0
pyr :0
tet :0
Patches:
Patch Size Name
0 150 inlet-flame
1 400 plate
2 600 atmosphere
3 50 inlet-inert
4 2400 simmetry2
5 2400 simmetry1
CellZones:
Zone Size Name
--> FOAM FATAL ERROR : faces deallocated
From function const faceList& polyMesh::allFaces() const
in file meshes/polyMesh/polyMesh.C at line 655.
FOAM aborting
Foam::error::printStack(Foam:stream&)
Foam::error::abort()
Foam::polyMesh::allFaces() const
Foam::polyPatch::polyPatch(Foam::word const&, int, int, int, Foam::polyBoundaryMesh const&)
Foam::polyPatch::addwordConstructorToTable<foam::p olypatch>::New(Foam::word const&, int, int, int, Foam::polyBoundaryMesh const&)
Foam::polyPatch::New(Foam::word const&, Foam::word const&, int, int, int, Foam::polyBoundaryMesh const&)
Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::List<foam::word> const&)
gmsh2ToFoam [0x8052fe0]
__libc_start_main
__gxx_personality_v0
Aborted
(I had removed the code for delete unused points)
Bye
Marco
Old   March 9, 2007, 19:34
Default Hi, I tested your .geo also w
  #13
Takuya OSHIMA
I tested your .geo also with Gmsh 2.0.4, and found the resulting .msh after generating a 3D mesh contains no volumetric elements (tet, hexa, ...) even though a physical volume 186 is defined. I guess the last line of your .geo
should be replaced by
Physical Volume("internalField") = {1,2,3,4,5,6,7,8};
and gmsh2ToFoam converts the mesh successfully (although checkMesh fails the face skewness test). Could you have a careful look into the generated mesh with Tools -> Visibility menu of Gmsh?
Takuya
Old   March 10, 2007, 12:45
Default With Physical Volume("interna
  #14
Marco Moscaritolo
With
and
I don't see mesh into tools -> Visibility -> Mesh partitions, but I see volume in Physical partitions.
Bye
Marco
Old   March 10, 2007, 19:36
Default No, no. You must *remove* the
  #15
Takuya OSHIMA
No, no. You must *remove* the line
and add the line
instead.
Checking your physical volume definition with Tools -> Visibility -> Physical groups menu and selecting internalField -> Apply you should only see
which apparently does not contain any internal mesh. But replacing volume 186 with 1-8 and doing the same checking you'll see the entire volume with internal mesh.
And the final generated 3D .msh's follow the figures above -- the .msh genereted by your original .geo does not contain any internal meshes but the corrected one does.
T.
Old   March 10, 2007, 19:45
  #16
Takuya OSHIMA
and add the line
instead.
Checking your original physical volume definition 186 with Tools -> Visibility -> Physical groups menu and selecting internalField -> Apply you should only see
T.
Old   March 11, 2007, 05:23
Default Sorry, I'm explained to me bad
  #17
Marco Moscaritolo
Sorry, I'm explained to me badly ... I use ONLY Physical Volume("internalField") = {186}; or Physical Volume("internalField") = {1,2,3,4,5,6,7,8};. With your explanation I solved the problem.
Thanks for your patience.
Marco
Old   October 4, 2007, 08:14
Default Hi, I just found the gmshFoam
  #18
David Segersson
segersson is on a distinguished road
I just found the gmshFoam utility on the Wiki, quite impressing. I'm also using gmsh, constructing the .geo files from ESRI shape-files with a small Python module. I've run into some serious trouble using gmsh that maybe you can help me with.
I'm extruding multiple surfaces (simultainously) to form a volume mesh of a city block. The buildings are later cut out of the mesh using OpenFoam utilities:
The conversion using gmsh2ToFoam produces warnings (could not match face and unused points) and the short mesh check says that the mesh is invalid. A total meshCheck produces a great number of errors, failing 6 mesh checks. This despite the fact that the mesh is quite simple. A visual check of the 2d-mesh that is extruded in gmsh makes it hard to understand all the errors. My conclusion is that something goes wrong either during the extrusion (although gmsh does not complain) or during the export to OpenFOAM. I'm having a really hard time figuring out how to fix this, and considering the ~2 weeks I've put into getting the shapeToGeo conversion funcion I do not want to let it go.
Does anybody (7islands?) have the possibility to try an example .geo file:
buildings.geo
and maybe give some suggestion on what´s going wrong.
The .geo-file uses the pos-file as a background-grid/size function when setting the mesh sizes. The files need to be in the same directory or the link in the .geo-file should be changed.
With hope of help
/David
segersson is offline   Reply With Quote
Old   October 4, 2007, 08:33
Default A small correction, I could n
  #19
David Segersson
A small correction,
I could not upload the .pos file since it was to big. I commented out this part from the .geo-file and it works anyway, just giving other cell sizes.
Regards
David
Old   October 4, 2007, 15:21
Default Hi David, just ran gmsh2.08
  #20
Mattijs Janssens
mattijs is on a distinguished road
Hi David,
just ran gmsh2.08 on your .geo case, ran it through 1.4.1 gmshToFoam and get a lot of warnings of the form
--> FOAM Warning :
From function gmshToFoam
in file gmshToFoam.C at line 799
Could not match gmsh face 3(215 2086 214) to any of the interior or exterior faces that share the same 0th point
which means that the surfaces you export (triangles I assume) don't cover the faces of your volume mesh? (gmshToFoam tries to use the surface mesh triangles/quads to denote the patches of the volume mesh)
Anyway end up with following geometry
which makes me believe your geometry consists of multiple parts and only one gets meshed or exported?
mattijs is offline   Reply With Quote
SimpleFoam cannot open include file Marija OpenFOAM Running, Solving & CFD 1 October 28, 2020 10:35
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 11:32
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
