[snappyHexMesh] Mesh error while using two versions of OpenFoam
Old   February 8, 2019, 11:43
Default Mesh error while using two versions of OpenFoam
Muhammad Omer Mughal
Muhammad Omer Mughal is on a distinguished road
Hi all Foamers
I created a complex mesh of buildings for ChtmultiregionFoam simulation in OF1712. However the mesh is not readable by OF6 as OF1712 uses domain marker approach rather than the CAD based approach and "location in Mesh" in normal SHM is defined as "locations in Mesh". This generates some illegal characters that are not read by OF6 SHM. Is there a tool that can make both meshes compatible?
I need OF6 since modified solver is compiled with OF6 and does not compile with OF1712.
I 'll be grateful for help.
Regards
Omer
Muhammad Omer Mughal is offline   Reply With Quote
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM nsf OpenFOAM Meshing & Mesh Conversion 86 February 8, 2023 10:30
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
[Commercial meshers] OpenFoam Mesh to Fluent Mesh in parallel case DominicTNC OpenFOAM Meshing & Mesh Conversion 3 November 22, 2017 09:19
[Other] vtk mesh or Abaqus mesh to OpenFOAM bigphil OpenFOAM Meshing & Mesh Conversion 27 November 23, 2015 17:31
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 07:18
