[Other] Having serious difficulty generating a mesh inside a pipe
Like Tree5Likes
  • 1 Post By yambanshee
  • 1 Post By RobertHB
  • 1 Post By Tobi
  • 1 Post By Rakkiran
Old   November 6, 2018, 23:17
Default Having serious difficulty generating a mesh inside a pipe
jeev1 is on a distinguished road
Hello Guys,
I am really new to OpenFOAM. I need to simulate a fluid flow inside a tube. Please recommend a CAD software where i can design a geometry and download in seperate .stl files? eg: inlet, outlet and the tube
Thanks in advance!
jeev1 is offline   Reply With Quote
Old   November 7, 2018, 01:38
Zander Meiring
yambanshee is on a distinguished road
Salome is a commonly used CAD software for use with openFoam. It has it's own meshing capabilities too.
jeev1 likes this.
yambanshee is offline   Reply With Quote
Old   November 7, 2018, 03:22
Robert
RobertHB is on a distinguished road
Originally Posted by jeev1 View Post
Hello Guys,
Thanks in advance!
AutoCAD, FreeCAD, OpenFoam's own BlockMesh, Salome.
You want seperate .stl files for your mesh? That might not work with OpenFoam. But you could do the meshing with salome, which can create different patches from an stl.
jeev1 likes this.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Old   November 13, 2018, 06:31
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Maybe I do not get your statement correctly but *.STL files are a common geometry data for OpenFOAM in combination with snappyHexMesh.
jeev1 likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   November 13, 2018, 06:37
Robert
You are right Tobias. Seems my answer was misleading.
As i understand OP want's to use seperate .stl files to form one geometry. From my experience, using three seperate cylinders to form a larger one, snappyHexMesh struggles to mesh multiple .stl files into a meaningful topography. I, at least, never got it working.
jeev1 likes this.
Old   December 21, 2018, 03:36
Thanks for the reply guys! I used salome to separate the geometry.
Old   December 21, 2018, 04:01
Default New to OpenFOAM Meshing -- Need Help
Hi Guys!
As a part of Masters Thesis, I have to simulate a fluid flow through 1mm thick curved pipe using OpenFOAM. I created my geometry using SolidWorks (Screenshot attached herewith). I created separate geometry for pipe, inlet and outlet and assembled in SolidWorks and finally saved it in .stl file. Correct me if did anything wrong as I'm an absolute beginner when it comes to OpenFOAM.
I tried SnappyHexMesh, ICEM and also Salome to create the mesh but couldn't create a perfect mesh. I know that I am doing it wrong but and I am exhausted searching for a solution. My deadline for Thesis submission is very near and I'm going no where with my simulation.
I hope someone can help me on what is the best way to mesh a geometry such as mine and which is the best software to do so. And also please recommend if there's any tutorial available for this type of meshing.
Thanks in advance!
Old   December 22, 2018, 01:54
Raj Kiran
Rakkiran is on a distinguished road
Hello jeev1,
OpenFOAM is mostly learned by trial and error.
Just try this if it helps you in anyway https://holzmann-cfd.de/openfoam/vid...meshing-a-pipe.
you can even try salome tutorial https://www.youtube.com/watch?v=g5tyw1tP_U0
Regards,
Raj
jeev1 likes this.
Rakkiran is offline   Reply With Quote
Old   January 7, 2019, 03:49
Robert
Make sure that your object, including the inlet/outlet patches, is watertight. Otherwise snappyHexMesh will not create a mesh from it.
Old   February 14, 2019, 16:54
Default hopscotch cylinder hex meshing
Tom Alderweireldt
Talder is on a distinguished road
http://matveichev.blogspot.com/2013/...with-gmsh.html
For me this enlightened me to start building arbitrary piping hex meshes.
Hope you like it too,
Tom.
Talder is offline   Reply With Quote
meshing 3d, openfoam
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 11:40
[GAMBIT] 3D mesh for pipe intersection pranab_jha ANSYS Meshing & Geometry 3 May 28, 2010 01:33
Difficulty in generating 3-D mesh Rucy FLUENT 3 November 10, 2005 09:53
