[blockMesh] blockMeshing Annular cylinder ?!!
Old   July 25, 2015, 10:18
Default blockMeshing Annular cylinder ?!!
Ananthakrishnan.A.S
Ananthakrishnan is on a distinguished road
Send a message via Skype™ to Ananthakrishnan
I am trying to create a annular cyclinder mesh using blockmesh similar to mesh shown below
(Its hollow inbetween. Flow occurs only in the annular section)
I started with a simple cyclinder and tried deleting the central block/assigning the inbetween plane as wall/etc.... but nothing worked.
Please let me know if it is possible to create such a mesh through blockMesh or should i create a geometry and snap it..
Any help/hint would be of great use!!!
Thank you very much
Regards,
Ananthakrishnan
Ananthakrishnan is offline   Reply With Quote
Old   July 31, 2015, 16:26
Alex
zfaraday will become famous soon enough
Hello Ananthakrishnan,
Yes, it is possible to do what you want with blockMesh. It may exist more than one possible approach but I have done something similar following the steps bellow:
  • Create first only the first quarter of your hollow cylinder (it's easy to do so by using only 8 vertices and joining them by arcs)
  • Create the first half of your cylinder by mirroring the quarter cylinder you previously created. To do so you have to use the utility mirrorMesh.
  • Create the complete hollow cylinder by mirroring the half one. Again, use the utility mirrorMesh adjusting properly its corresponding dictionary in the system directory.
Maybe it's not the most straightforward approach, but it worked for me in the past.
Hope it helps,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   May 7, 2019, 05:51
bharadwaz
bharadwaz is on a distinguished road
Originally Posted by Ananthakrishnan View Post
Thank you very much
Regards,
Ananthakrishnan
name cathode; // name of the set
type cellSet;
action new; // creating a new set or add
source cylinderAnnulusToCell; // using a selection box
sourceInfo
p1 ( 0 0 0.03 ); // start point on cylinder axis
p2 ( 0 0 0.07 ); // end point on cylinder axis
outerRadius 0.009 ;
innerRadius 0.004 ;
bharadwaz is offline   Reply With Quote
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 02:19
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 16:16
Forces Acting on a Rotating Cylinder (Moving Mesh) dreamchaser CFX 5 April 25, 2015 06:01
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
