[Other] How to create inclined mesh in OpenFOAM?
Old   April 20, 2019, 13:32
Default How to create inclined mesh in OpenFOAM?
Md Akter Uz Zaman
Akter Uz Zaman is on a distinguished road
Hello! I want to create a Mesh around a cylinder using blockMesh dictionary. The mesh should be as shown in the attached image.I tried to figure out using several tutorials in youtube and online but failed miserably. The grid lines should be normal to the cylinder and not parallel to each other. Please help me in order to solve the problem.
Akter Uz Zaman is offline   Reply With Quote
Old   April 20, 2019, 17:16
fresty is on a distinguished road
Hi. Your comment regarding grid lines being normal to the discretized circle while having two distinct mesh zones, seems a bit counter-intuitive.
Your specified separation profile is a horizontal line (representative of ground/ soil plane), hence to avoid violating grid quality parameters, it would conform optimally to the provided boundaries while maintaining the compatible/ matching interface boundary. If you're not simulating mesh deformation (which most likely you are), then methods such as setFields would allow you to have your desired single region mesh (flow around a cylinder) as well as multiphase and/ or multicomponent domain.
fresty is offline   Reply With Quote
[ICEM] How can I create prism mesh for a 3D domain surrounded by a torus? lzgwhy ANSYS Meshing & Geometry 5 May 18, 2017 17:10
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 09:03
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
