[blockMesh] create a mesh without reading from dictionary file
Like Tree1Likes
  • 1 Post By yambanshee
Old   July 8, 2019, 23:40
Lightbulb create a mesh without reading from dictionary file
Jie Ren
Jieren is on a distinguished road
Dear foamers,
I want to generate a new mesh (like a simple cubic one) with 3 vectors calculated from my program, but without referring to the 'blockMeshDict' file.
Details as below:
To generate a simple cubic blockmesh with all its vertices' positions: 8 vertices in total, which can be derived from two vectors, like (0,0,0) and (1,1,1).
The third vector, like (20,20,20) , represent the number of grids in each coordinate.
NO boundaries and patches are defined, neither the other mesh settings!
Cause it is just used for visualization.
To sum up, use 3 vectors to generate a very simple mesh in a program, without reading the 'blockMeshDict' file, and without using the 'blockMesh' utility (but may use it in another form, i am not sure about it...).
I've got these 3 vectors in my program, but they are case-dependent, it is cumbersome to edit the file every time....that's why I start to think it.
The mesh generated should be identity or similar to that using the 'blockMeshDict' file (as below) and 'blockMesh' utility.
convertToMeters 1;
vertices //can be derived from two vectors (0,0,0) & (1,1,1)
(0 0 0)
(1 0 0)
(1 1 0)
(0 1 0)
(0 0 1)
(1 0 1)
(1 1 1)
(0 1 1)
blocks //the third vector (20 20 20) is necessary
hex (0 1 2 3 4 5 6 7) (20 20 20) simpleGrading (1 1 1)
boundary //no defined boundary & patch, just for visualization
How to create the mesh with 3 known vectors within a program?
Should I generate a 'dictionary' object manually without IO, then use it for mesh generation? I am confused about it...
Any answer is welcomed,
thanks in advance!
Jieren
Jieren is offline   Reply With Quote
Old   July 9, 2019, 03:44
Zander Meiring
yambanshee is on a distinguished road
Originally Posted by Jieren View Post
Dear foamers,
Details as below:
convertToMeters 1;
(0 0 0)
(1 0 0)
(1 1 0)
(0 1 0)
(0 0 1)
(1 0 1)
(1 1 1)
(0 1 1)
thanks in advance!
Jieren
I would make the dictionary with your own script. I currently have a python script that creates my blockMeshDict for me, and then simply runs the blockMesh program
Jieren likes this.
yambanshee is offline   Reply With Quote
mesh adaption, mesh generation
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
SimpleFoam cannot open include file Marija OpenFOAM Running, Solving & CFD 1 October 28, 2020 10:35
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
