October 26, 2017, 10:41 |
Geometry inside mesh
David Buentello
Rep Power: 9 |
Fellow foamers,
I generated a packed bed using Blender + SnappyHex (please see image attached), however whenever I try to run a simulation the solver crashes, and I get an error related to the solver (I think its the pressure): Code:
PISO: Operating solver in PISO mode Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.005 Courant Number mean: 7.65614e-06 max: 0.355821 smoothSolver: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 6.50901e-06, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) at ??:? #4 Foam::DICSmoother::DICSmoother(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:? #5 Foam::lduMatrix::smoother::addsymMatrixConstructorToTable<Foam::DICSmoother>::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:? #6 Foam::lduMatrix::smoother::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::dictionary const&) at ??:? #7 Foam::GAMGSolver::initVcycle(Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::lduMatrix::smoother>&, Foam::Field<double>&, Foam::Field<double>&) const at ??:? #8 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #9 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #10 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/icoFoam" #11 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/icoFoam" #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/icoFoam" Floating point exception (core dumped) |
October 26, 2017, 11:40 |
Rep Power: 8 |
in blender there is a function to set the gap, try to play it, then you can import the geometry to SOLIDWORKS or other similar programs, conduct an interference check, and then export in the required format
October 27, 2017, 02:46 |
Pascal Balz
Rep Power: 11 |
Hi pyroWinter,
could you please post the output of checkMesh -constant? Most likely this is a mesh problem but it could also be related to your boundary conditions. The reason for this is that the solver solves for Uy only, but the current should be in z direction if I see that correctly. This means that your inflow U boundary condition is wrong which could easily lead to a solver crash.
Regards, Pascal |
October 27, 2017, 04:18 |
David Buentello
Rep Power: 9 |
Thank you both for your answers. I hadnt run the checkMesh. This certainly looks not good:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.0-dbb428a3a855 Exec : checkMesh Date : Oct 27 2017 Time : 09:07:47 Host : "david-VirtualBox" PID : 11119 I/O : uncollated Case : /home/david/Bed nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 591951 faces: 1712347 internal faces: 1641745 cells: 563168 faces per cell: 5.95576 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 542734 prisms: 11007 wedges: 0 pyramids: 0 tet wedges: 35 tetrahedra: 0 polyhedra: 9392 Breakdown of polyhedra by number of faces: faces number of cells 4 4447 5 4945 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 17 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 563152 cells to cellSet region0 <<Writing region 1 with 1 cells to cellSet region1 <<Writing region 2 with 1 cells to cellSet region2 <<Writing region 3 with 1 cells to cellSet region3 <<Writing region 4 with 1 cells to cellSet region4 <<Writing region 5 with 1 cells to cellSet region5 <<Writing region 6 with 1 cells to cellSet region6 <<Writing region 7 with 1 cells to cellSet region7 <<Writing region 8 with 1 cells to cellSet region8 <<Writing region 9 with 1 cells to cellSet region9 <<Writing region 10 with 1 cells to cellSet region10 <<Writing region 11 with 1 cells to cellSet region11 <<Writing region 12 with 1 cells to cellSet region12 <<Writing region 13 with 1 cells to cellSet region13 <<Writing region 14 with 1 cells to cellSet region14 <<Writing region 15 with 1 cells to cellSet region15 <<Writing region 16 with 1 cells to cellSet region16 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology bed 30006 36208 ok (closed singly connected) walls 21286 21867 ok (non-closed singly connected) inlet 9742 9969 ok (non-closed singly connected) oulet 9568 9792 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.424503 -0.424643 -0.203557) (0.424503 0.424651 0.326444) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-9.14422e-17 -4.27301e-16 5.18499e-16) OK. Max cell openness = 3.08821e-16 OK. Max aspect ratio = 10.1721 OK. Minimum face area = 2.57596e-09. Maximum face area = 0.00018358. Face area magnitudes OK. Min volume = 6.21598e-13. Max volume = 1.42826e-06. Total volume = 0.262035. Cell volumes OK. Mesh non-orthogonality Max: 64.9884 average: 3.9514 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 4.14991, 1 highly skew faces detected which may impair the quality of the results <<Writing 1 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End I will try different things and if I solve this I will post it. Again, thanks. |
October 27, 2017, 11:35 |
David Buentello
Rep Power: 9 |
Indeed the problem was in the mesh. It had to do with something I modified in Blender to account for the collision (vertexes were placed inside my domain). Everything is working now, time to wait for the simulations to finish.
November 11, 2019, 06:13 |
Dear David,
I want to generate the packed bed media too. Your post interests me a lot. I want to try the blender software. Could you share some tutorials of blender? Best regards, Chengan |
[snappyHexMesh] SHM error: inside mesh not possible | Naresh yathuru | OpenFOAM Meshing & Mesh Conversion | 1 | January 10, 2017 23:58 |
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre | powpow | CFX | 3 | December 20, 2012 09:14 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Volume mesh inside a certain geometry | samiam1000 | Main CFD Forum | 0 | October 26, 2010 12:54 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
