[Technical] CCMIO Library 32-bit label maximum
Old   August 15, 2019, 18:48
Default CCMIO Library 32-bit label maximum
miragemobile is on a distinguished road
Hello everyone,
I am working with converting larger Star-CCM+ meshes into OpenFOAM. I'm currently exceeding the 32-bit label maximum, as the converter is written using doubles and int_32t variable type.
Has anyone implemented a 64-bit label version of this utility?
from the wmake/script/have_ccmio file:
    # The libccmio uses int32_t.
    # The OpenFOAM adapter thus requires additional work for 64-bit labels.
    # The OpenFOAM adapter was originally only designed for 'double'
    local good
    if [ "$WM_LABEL_SIZE" = 32 ]
    then
        if [ "$WM_PRECISION_OPTION" = DP ]
        then
            good=true
        else
            [ -n "$warn" ] && echo "$warn (double precision only)"
            no_ccmio
            return 1
        fi
    else
        [ -n "$warn" ] && echo "$warn (32-bit labels only)"
        no_ccmio
        return 1
    fi
miragemobile is offline   Reply With Quote
Saved in Workbench 32 bit, open in Workbench 64 bit. Black Ni ANSYS 2 July 28, 2011 09:32
Issue with running in parallel on multiple nodes daveatstyacht OpenFOAM 7 August 31, 2010 17:16
64 Bit software or 64 bit compatibility? EphemeralMemory ANSYS 1 August 31, 2010 05:29
UDF problem/32 bit vs. 64 bit RE13 FLUENT 2 February 25, 2008 11:31
fluent 32 bit maximum RAM Mike FLUENT 2 August 19, 2006 09:45
