August 22, 2019, 09:04 |
topoSet from STL
Olivier Dambron
Rep Power: 9 |
Hi everyone,
Would you know how to use topoSet to select all the cells within the boundaries of an STL geometry. So far I was using as a source searchableSurfaceToFaceZone, but my fvOption affects the cells located on the faces only. topoSetDict actions ( { name sprink; type faceZoneSet; action new; source searchableSurfaceToFaceZone; sourceInfo { surface triSurfaceMesh; name "sprinklers.stl" useSurfaceOrientation true; outsidePoints ((1.9965 1.10433 8.35321)); includeCut false; includeInside true; includeOutside false; nearDistance -1; curvature 0.1; } } { name sprinklers; type cellSet; action new; source faceZoneToCell; sourceInfo { name sprink; option master; } } fvOptions sprinklers { type scalarSemiImplicitSource; active true; scalarSemiImplicitSourceCoeffs { cellSet sprink; selectionMode cellSet; volumeMode specific; injectionRateSuSp { h (-27000 0); } } } thanks for your help Olivier. |
August 22, 2019, 10:03 |
anonymous
Rep Power: 14 |
Hi!
How do you generate your mesh? If you are using snappyHexMesh, you can create a cellZone for these cells inside/outside of that STL file if it is a closed surface (it should be). And you don't even need topoSet. You will have your cellZones after the meshing. |
August 22, 2019, 11:31 |
Olivier Dambron
Rep Power: 9 |
Many thanks simrego!
You solved my issue. Here's what I did inside snappyHexMeshDict for those who may need it: geometry { } sprinklers.stl { type triSurfaceMesh; name sprinklers; } } refinementSurfaces { sprinklers { level (0 0); faceZone faceZone1; cellZone cellZone1; cellZoneInside inside; boundary internal; } |
November 8, 2020, 21:30 |
Farzad Faraji
Rep Power: 7 |
Dear Simrego
What should I do if I generate my mesh from an external source(In my case ansysMeshing), and still I want to add zone in the toposetdict? Thanks Farzad |
[mesh manipulation] topoSet for stl files | Owais Shabbir | OpenFOAM Meshing & Mesh Conversion | 4 | November 8, 2020 17:42 |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
Possible to create cyliner baffle (internal) using topoSet or stl Mesh? | keepfit | OpenFOAM | 4 | February 19, 2017 14:40 |
[ICEM] STL file! How is it useful? | bidi | ANSYS Meshing & Geometry | 0 | December 26, 2016 21:33 |
[snappyHexMesh] Experimentally obtained STL file for internal Flow SnappyHexMesh | Irish09 | OpenFOAM Meshing & Mesh Conversion | 9 | April 7, 2012 08:50 |
