[snappyHexMesh] bad grid problem analysis
Like Tree1Likes
  • 1 Post By xwang252
Old   September 13, 2019, 03:35
Default bad grid problem analysis
John Wang
xwang252 is on a distinguished road
I am using snappyHexMesh generating grid but it always has some very strange grid at the geometry surface. Can any expert tell the reason and solution? Thanks.
xwang252 is offline   Reply With Quote
Old   September 14, 2019, 00:48
Default grid problem
John Wang
I used snappyHexMesh to generate mesh. I got this result as attached that the snap function cannnot capture the geometry (blue parts) accurately. Can any expert tell the reason and solution? Thanks.
Old   September 15, 2019, 07:48
John Wang
The problem can be solved in some degree by adjust the snap controls setting.
Old   September 15, 2019, 07:52
John Wang
I encountered a new problem that grid at some corners of the geometry has been very weird. Can any expert tell the reason and solution?
Thanks
Old   September 15, 2019, 07:53
John Wang
Thanks
Even refining the grid near the geometry would not solve this problem.
Old   September 17, 2019, 00:32
John Wang
I have finally fixed this problem.
it needs to be clarified that
SnappyHexMesh does has the capability to snap even sharp corners of the geometry. The key parameters for this problem are:
base mesh size
nCellsBetweenLevels - 6 //solve bad grids at STL surface
resolveFeatureAngle - 45 //value less than 90 could snap the perpendicular STL edge
features{*.eMesh} //solve bad/rounded grids at STL surface edge
refinementSurfaces{level(min,max)} //increase max value could help to snap edge more accurately in the same time keeping the STL surface grid size small
nSmoothPatch - 3 // setting this value a little bit larger help solve bad grid problem but not too large which would distort other good grids
nFeatureSnapIter - 5 //setting this value a little bit larger help solve bad grid problem but not too large which would increase iteration time significantly
explicitFeatureSnap - true //would help snap features
jherb likes this.
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 05:53
Fine/Turbo cannot open grid built by IGG, Configuration file problem? wkjshon Fidelity CFD 6 March 29, 2016 02:09
Thermal Analysis Problem ChristianGermany ANSYS 0 September 23, 2015 18:52
Problem with nozzle analysis Aristine Main CFD Forum 0 March 15, 2012 07:28
Problem with staggered grid on numerical simulation gtr84 Main CFD Forum 1 February 15, 2012 07:58
