September 19, 2019, 09:36
snappyHexMesh minRefinementCells
Gareth
Hi All
I am trying to figure out if the minRefinement feature in sanppyHexMesh is functional.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
G.stl
type triSurfaceMesh;
name Box;
regions
Inlet
name Inlet;
Outlet
name Outlet;
rig
name rig;
port
name port;
t_in
name t_in;
t_out
name t_out;
exhaust
name exhaust;
Walls
name walls;
// Settings for the castellatedMesh generation.
castellatedMeshControls
// Refinement parameters
// If local number of cells is >= maxLocalCells on any processor
// switches from from refinement followed by balancing
// (current method) to (weighted) balancing before refinement.
maxLocalCells 2000000;
// Overall cell limit (approximately). Refinement will stop immediately
// upon reaching this number so a refinement level might not complete.
// Note that this is the number of cells before removing the part which
// is not 'visible' from the keepPoint. The final number of cells might
// actually be a lot less.
maxGlobalCells 10000000;
// The surface refinement loop might spend lots of iterations
// refining just a few cells. This setting will cause refinement
// to stop if <= minimumRefine are selected for refinement. Note:
// it will at least do one iteration (unless the number of cells
// to refine is 0)
minRefinementCells 5;
// Number of buffer layers between different levels.
// 1 means normal 2:1 refinement restriction, larger means slower
// refinement.
nCellsBetweenLevels 3;
features
file "Walls.eMesh";
level 6;
file "Inlet.eMesh";
level 4;
file "Outlet.eMesh";
level 4;
file "Lower_port.eMesh";
level 4;
file "turbine_walls.eMesh";
level 4;
file "turbine_inlet.eMesh";
level 4;
file "turbine_outlet.eMesh";
level 4;
file "exhaust_outlet.eMesh";
level 4;
refinementSurfaces
Box
level (2 5);
regions
Inlet
level (3 3);
patchInfo{type patch;}
Outlet
level (3 3);
rig
level (3 3);
port
level (3 3);
t_in
level (3 3);
t_out
level (3 3);
exhaust
level (3 3);
Box_Walls
level (5 6);
patchInfo{type wall;}
resolveFeatureAngle 30;
refinementRegions
locationInMesh (3 3 3);
allowFreeStandingZoneFaces false;
snapControls
nSmoothPatch 4;
tolerance 2;
nSolveIter 30;
nRelaxIter 5;
nFeatureSnapIter 10;
// Settings for the layer addition.
addLayersControls
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
walls
nSurfaceLayers 3;
expansionRatio 1.1;
finalLayerThickness 0.3;
minThickness 0.05;
nGrow 0;
featureAngle 60;
nRelaxIter 3;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 2;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 1;
minMedianAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1e-13;
minTetQuality 1;
minArea -1;
minTwist 0.05;
minDeterminant 0.001
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1;
nSmoothScale 4;
errorReduction 0.75;
mergeTolerance 1e-6;
This would be my snappyHexMeshDict. As you can see i set the min number of cells to refine at 5. I expect it to stop performing fetaure iterations once the following line is printed in the log:
Marked for refinement due to explicit features : 4 cells.
However from the attached log file you can see it just keep ticking on.
I thought once it find less than the specified number of cells it would at most perform one more iteration and then stop. For example iteration 22 - 23, in the attached file. I have copied that particular section here for ease of reading.
Feature refinement iteration 22
Marked for refinement due to explicit features : 2 cells.
Determined cells to refine in = 23.23 s
Selected for feature refinement : 4 cells (out of 9712249)
Edge intersection testing:
Number of edges : 34066119
Number of edges to retest : 358
Number of intersected edges : 3987980
Refined mesh in = 13.12 s
After refinement feature refinement iteration 22 : cells:9712277 faces:34066119 points:15136146
Cells per refinement level:
0 981310
1 98976
2 275530
3 748674
4 1834349
5 3023150
6 2750288
Balanced mesh in = 63.61 s
After balancing feature refinement iteration 22 : cells:9712277 faces:34066119 points:15136146
0 981310
1 98976
2 275530
3 748674
4 1834349
5 3023150
6 2750288
Feature refinement iteration 23
Determined cells to refine in = 24.62 s
Selected for feature refinement : 2 cells (out of 9712277)
Number of edges : 34066158
Number of edges to retest : 212
Number of intersected edges : 3987983
Refined mesh in = 13.26 s
After refinement feature refinement iteration 23 : cells:9712291 faces:34066158 points:15136157
0 981310
1 98976
2 275530
3 748674
4 1834349
5 3023148
6 2750304
Balanced mesh in = 63.06 s
After balancing feature refinement iteration 23 : cells:9712291 faces:34066158 points:15136157
0 981310
1 98976
2 275530
3 748674
4 1834349
5 3023148
6 2750304
Feature refinement iteration 24
But as you can see it started on iteration 24.
If i am not understanding the minRefienement word in the dictionary could someone explain it to me please.
Thanks in adv.
