Nafrin
Rep Power: 6 ![]() |
Hi all:
I am new in openfoam. I want to generate a sphere(hollow) with two inputs and two outputs. Anyone can help me? Thanks in advance! |
Damian Berghof
Rep Power: 11 ![]() |
Hello nafrin,
- what is your intention, your technical question, what should be simulated ? - have you already created a 3D model? - I strongly recommend to start with some simple tutorials, e.g. 'elbow' or 'TJunction' - one can find a ton of useful tutorials for beginners on the internet, for example here: https://www.youtube.com/channel/UCjd...xH9BqheyE82Vvw https://www.youtube.com/user/HolzmannCFD best, Damian
Get more support about Meshing with Salome and Visualization with ParaView in my growing groups ![]() https://bit.ly/2lFfDkQ https://bit.ly/2k2u8Pj |
Mikko
Rep Power: 12 ![]() |
Hi Nafrin,
For a simple geometry like a sphere, you can use blockMesh to generate the mesh. In this video you can see the blocking topology. It is an o-grid around the cube and then the surfaces/edges/points of the inner cube are projected on the sphere. Best, Mikko |
Nafrin
I want to create a reactor with 2inputs and 2 outputs. The sphere should be hollow and combustion will occur inside of the sphere. (I cannot attached the figure here. )
Nazia |
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) | Combas | SU2 | 44 | March 12, 2024 00:35 |
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM | nsf | OpenFOAM Meshing & Mesh Conversion | 86 | February 8, 2023 10:30 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
[Salome] Mesh conversion Salome to OpenFOAM | VMartinez | OpenFOAM Meshing & Mesh Conversion | 11 | April 21, 2014 02:54 |
