[mesh manipulation] 1D translation of solid inside of valve |
March 21, 2024, 09:09 |
Tiaan Janse van Rensburg
Good day I trust all well.
I'm new to CFD, OpenFOAM and C++ and would please like assistance on a problem. I want to simulate a Ratio Pressure Reducing valve where when the fluid pressure interacts (hits) with the piston inside the valve it pushes/slides backwards and fluid can flow through. Then when fluid flow/pressure drops valve closes again because force on valve drops. I have attached a picture of the part where the blue piston is all the way to the left and valve is fully open. Fluid flows in from right to left. I looked at rigidBodyDynamics to use for dynamicMeshDict. I exported the piston as a .stl file and used rigidBody to read .stl file in dynamicMeshDict. This did not work. I have no idea how te mesh the valve housing then mesh the piston and make the piston translate forward and backword. I tried changing and adapting DTCHullMoving and floatingObject but no luck. if anybody can help me or fill me in on a simpler way that would be much appreciated. Thanks in advance. |
Conjugate Heat Transfer: Solid Time Step in Transient Simulation, DO Model | Dingens | FLUENT | 0 | July 9, 2021 06:19 |
Rectangular Tank with viscoelastic solid inside - help needed | srinc | CFD Freelancers | 0 | April 26, 2019 09:51 |
Rectangular Tank with collagen (or viscoelastic solid) inside - reg | srinc | OpenFOAM | 0 | March 25, 2019 09:23 |
[DesignModeler] Fill command with valve inside | Orb | ANSYS Meshing & Geometry | 1 | October 25, 2012 02:26 |
[DesignModeler] Creating Fluid Body Inside Solid Part | VU_Engineer | ANSYS Meshing & Geometry | 1 | February 24, 2012 21:28 |
